メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
RYOBI P422 Wheel Guard Replacement
    1. RYOBI P422 Wheel Guard Replacement, Battery and Handle: 手順 1、 2の画像 1 RYOBI P422 Wheel Guard Replacement, Battery and Handle: 手順 1、 2の画像 2
      • To remove the battery press down on the two buttons located on each side of the battery and pull away from the body of the grinder.
      • To remove the handle hold grinder with one hand and use the other hand to unscrew the handle with a counter-clockwise motion
      FixBotに聞いてみる
      コメントを追加
    1. RYOBI P422 Wheel Guard Replacement, Wheel Guard: 手順 2、 3の画像 1 RYOBI P422 Wheel Guard Replacement, Wheel Guard: 手順 2、 3の画像 2 RYOBI P422 Wheel Guard Replacement, Wheel Guard: 手順 2、 3の画像 3
      • Do not perform this task immediately after using the grinder for grinding/cutting. The blade will be to hot to touch and could result in injury.
      • Fully press the spindle lock button.
      • With the spindle lock button held down, use the wrench provided to loosen the clamp nut. Once loose, you can use your fingers to unscrew the nut completely
      FixBotに聞いてみる
      コメントを追加
    2. RYOBI P422 Wheel Guard Replacement: 手順 3、 2の画像 1 RYOBI P422 Wheel Guard Replacement: 手順 3、 2の画像 2
      • Remove your grinding/cutting tool by simply pulling it off the spindle.
      • Next remove the disc flange (a.k.a spacer) by pulling it off of the back end of the spindle.
      • The disc flange has two small raised edges on its back side. These ridges need to be aligned with the two flat faces at the back of the spindle lock when reassembled. This will ensure a safe, snug fit for your grinding blades.
      FixBotに聞いてみる
      コメントを追加
    3. RYOBI P422 Wheel Guard Replacement: 手順 4、 3の画像 1 RYOBI P422 Wheel Guard Replacement: 手順 4、 3の画像 2 RYOBI P422 Wheel Guard Replacement: 手順 4、 3の画像 3
      • Lift the clasp on the grinder guard. Make sure the clasp is completely loosened before proceeding.
      • Rotate the grinder guard so that the three notches on its interior align with the three slots on the grinding head assembly.
      • Once aligned, simply pull the guard off.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
3人の作成者と共同で作成されました。
John Lamanuzzi
メンバー登録日: 03/20/15
229 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 3-6, Duarte Spring 2015 UMass Dartmouth, Team 3-6, Duarte Spring 2015人のメンバー
UMASSD-DUARTE-S15S3G6
3 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 18
過去 30 日: 70
今までの合計 4,378
