メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
RCA RCT6203W46 Rear Camera Replacement
必要な工具と部品
    1. RCA RCT6203W46 Rear Camera Replacement, Front and Rear Camera: 手順 1、 2の画像 1 RCA RCT6203W46 Rear Camera Replacement, Front and Rear Camera: 手順 1、 2の画像 2
      • Make sure the device is off to reduce the chance of an electrical shock. To turn off the device, press and hold the power button.
      • Use a Phillips #00 Screwdriver to unscrew the 4mm (5/32 in.) screws from the back cover of the tablet.
      FixBotに聞いてみる
      コメントを追加
    2. RCA RCT6203W46 Rear Camera Replacement: 手順 2、 2の画像 1 RCA RCT6203W46 Rear Camera Replacement: 手順 2、 2の画像 2
      • Use a spudger to pry the back cover. Start from one edge of the back cover and slide across until the cover is lifted from the tablet body. Repeat for all edges.
      FixBotに聞いてみる
      コメントを追加
    3. RCA RCT6203W46 Rear Camera Replacement: 手順 3、 1の画像 1
      • Open the tablet cover carefully and slowly lengthwise.
      • The keyboard wire ribbon and rear speaker wire should be intact and connected with the back cover.
      • Opening the tablet abruptly may tear or damage cover attachments.
      FixBotに聞いてみる
      コメントを追加
    4. RCA RCT6203W46 Rear Camera Replacement: 手順 4、 1の画像 1
      • Use a spudger to flip up the flap of the ZIF connector that holds the keyboard wire ribbon.
      • Remove the wire ribbon from clamp.
      FixBotに聞いてみる
      コメントを追加
    5. RCA RCT6203W46 Rear Camera Replacement: 手順 5、 2の画像 1 RCA RCT6203W46 Rear Camera Replacement: 手順 5、 2の画像 2
      • Attached to the motherboard you will see two orange ribbons connected to black tabs.
      • Using both hands, place your thumbs gently on the black tab attached to the top and gently lift it.
      • Proceed to slide the orange colored ribbon out from underneath until it is detached from the black tab.
      FixBotに聞いてみる
      コメントを追加
    6. RCA RCT6203W46 Rear Camera Replacement: 手順 6、 1の画像 1
      • Use a spudger to pry and slide underneath the battery to unstick it from the LCD metal plate. It may take a good amount of force to remove.
      • Try to decrease battery deformation by using a spudger rather than prying with your hands.
      • Do not let battery fall back on adhesive, it will stick back onto the LCD metal plate.
      • Be careful to not puncture the battery. The battery may ignite or explode.
      FixBotに聞いてみる
      コメントを追加
    7. RCA RCT6203W46 Rear Camera Replacement: 手順 7、 2の画像 1 RCA RCT6203W46 Rear Camera Replacement: 手順 7、 2の画像 2
      • Gently remove the grey tape that's covering the grey colored wire until it is completely peeled off.
      • Peel off the black piece of tape to remove the antenna.
      FixBotに聞いてみる
      コメントを追加
    8. RCA RCT6203W46 Rear Camera Replacement: 手順 8、 1の画像 1
      • Unscrew three of the 4 mm screws on the motherboard using a Phillips #00 screwdriver.
      • After removing the screws, detach the motherboard from the rest of the tablet. Use a spudger to gently remove it, if necessary.
      FixBotに聞いてみる
      コメントを追加
    9. RCA RCT6203W46 Rear Camera Replacement: 手順 9、 1の画像 1
      • Locate the rear camera and use a prying tool to gently lift the rear camera off of the motherboard.
      FixBotに聞いてみる
      コメントを追加
    10. RCA RCT6203W46 Rear Camera Replacement: 手順 10、 1の画像 1
      • Detach the camera ribbon wire by lifting the tab and pulling the wire. This will leave you with the camera assembly.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Grace Chung
メンバー登録日: 09/21/16
212 ポイント
1ガイドが承認済み
チーム
UC Davis, Team 1-2, Oliver Fall 2016 UC Davis, Team 1-2, Oliver Fall 2016人のメンバー
UCD-OLIVER-F16S1G2
5 メンバー
8のガイドは作成済み
1件のガイドコメント
Where can I get the main board from RCT6203W46
top - 返信 共有
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 31
今までの合計 623
