メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Purse Strap Replacement
必要な工具と部品
    1. Purse Strap Replacement, Strap: 手順 1、 1の画像 1
      • Find a replacement strap or a long, thin piece of fabric you want to use for your purse strap.
      FixBotに聞いてみる
      コメントを追加
    2. Purse Strap Replacement: 手順 2、 1の画像 1
      • Make sure the strap is the correct length for your carrying preference. For example: crossbody, one-shoulder, crook of the elbow, etc.
      • Measurements will vary depending on preference.
      • For this project, we will be sewing a one-shoulder strap.
      FixBotに聞いてみる
      コメントを追加
    3. Purse Strap Replacement: 手順 3、 1の画像 1
      • Put the strap through the handle attachments.
      • Fold the end over.
      • There should be about 1/2 inch to 1 inch room for sewing.
      • Note: once the strap's end is folded over, make sure there is enough strap between each handle attachment for you to carry the bag.
      • Get your needle out and thread it with your preference of colored thread. We have used black.
      FixBotに聞いてみる
      コメントを追加
    4. Purse Strap Replacement: 手順 4、 2の画像 1 Purse Strap Replacement: 手順 4、 2の画像 2
      • Fold the strap so there is a half-inch between the stitching line and the handle attachment.
      • Sewing
      • Start on one edge and push the needle through both piece of strap.
      • Once the bit of thread is pulled through, go through the strap again, this time a pinch to the side of where you came up.
      • Repeat this until you have sewed a stitch across the entire width of the strap.
      • After reaching the opposite end, pull the needle through, bringing up as much excess thread as it allows. Note: do not pull too hard or the thread will rip.
      • Tie a knot at the end, keeping the knot close to the base of the thread. Repeat until you believe the knot is strong enough to hold.
      FixBotに聞いてみる
      コメントを追加
    5. Purse Strap Replacement: 手順 5、 1の画像 1
      • After you reach the other side of the strap's width, sew backwards on top of the existing seams for a locking stitch.
      • Cut excess string.
      FixBotに聞いてみる
      コメントを追加
    6. Purse Strap Replacement: 手順 6、 1の画像 1
      • Repeat steps 3-5 on the opposite handle attachment.
      FixBotに聞いてみる
      コメントを追加
    7. Purse Strap Replacement: 手順 7、 1の画像 1
      • After repeating the steps, each side of your strap should be sewed onto the handle attachments.
      FixBotに聞いてみる
      コメントを追加
終わりに
Make sure the stitches are secure by gently tugging on the strap. If it does not come un-stitched, then you are finished with your repair.
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Annie Chapman
メンバー登録日: 10/20/17
112 ポイント
1ガイドが承認済み
チーム
Missouri Western, Team S1-G6, Adkins Fall 2017 Missouri Western, Team S1-G6, Adkins Fall 2017人のメンバー
MWSU-ADKINS-F17S1G6
3 メンバー
2のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 20
過去 30 日: 64
今までの合計 2,622
