メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Proscan Tablet Touch Screen Replacement
必要な工具と部品
  1. Proscan Tablet Touch Screen Replacement, Touch Screen: 手順 1、 1の画像 1
    • Tools necessary for task.
    • Starting from the left to right
    • Metal Spudyer
    • Plastic opening tool
    • Precision tweezer
    • Point pen tool
    • Driver with bit size J0
    FixBotに聞いてみる
    コメントを追加
  2. Proscan Tablet Touch Screen Replacement: 手順 2、 1の画像 1
    • The backing of the tablet is fastened by simply snapping it in. Using the metal opening tool, pry between the plastic backing and the edge, but do not remove it yet. Work your way around until you have them separated.
    FixBotに聞いてみる
    コメントを追加
  3. Proscan Tablet Touch Screen Replacement: 手順 3、 1の画像 1
    • Once you have finished going around the edges of the tablet, look inside.
    FixBotに聞いてみる
    コメントを追加
  4. Proscan Tablet Touch Screen Replacement: 手順 4、 1の画像 1
    • You will notice two wires still connecting the backing to the computer. These are for the speakers.
    FixBotに聞いてみる
    コメントを追加
  5. Proscan Tablet Touch Screen Replacement: 手順 5、 1の画像 1
    • You can remove the speakers with your hands to free the backing completely.
    FixBotに聞いてみる
    コメントを追加
  6. Proscan Tablet Touch Screen Replacement: 手順 6、 1の画像 1
    • Next the following highlighted spots are screws. These screws must be loosened to separate the motherboard and digitizer from the outer glass components. Remember lefty loosely, righty tighty. All screws were placed on a magnet board to ensure they did not roll away
    FixBotに聞いてみる
    コメントを追加
  7. Proscan Tablet Touch Screen Replacement: 手順 7、 1の画像 1
    この手順で使用する道具:
    • There is some tape wire that links the screen to the grey digitizer. This can be gently pulled apart by the tweezers
    FixBotに聞いてみる
    コメントを追加
  8. Proscan Tablet Touch Screen Replacement: 手順 8、 1の画像 1
    • Next focus on the camera and volume components along the edges highlighted here. The screws have already been taken out, gently pull them off.
    FixBotに聞いてみる
    コメントを追加
  9. Proscan Tablet Touch Screen Replacement: 手順 9、 1の画像 1
    • Gently lift the green motherboard from the grey digitizer to ensure that all screws have been removed. The only connection remaining should be a tape wire to the battery.
    FixBotに聞いてみる
    コメントを追加
  10. Proscan Tablet Touch Screen Replacement: 手順 10、 1の画像 1
    • The last step is to remove the grey digitizer from the screen entirely. Note that the blue battery and green motherboard will still be attached, move them as one part
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
3 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Cameron Denny
メンバー登録日: 10/23/15
321 ポイント
2のガイドは作成済み
チーム
University of Memphis, Team 3-3, Kim Fall 2015 University of Memphis, Team 3-3, Kim Fall 2015人のメンバー
UM-KIM-F15S3G3
4 メンバー
4のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 33
今までの合計 6,199
