メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Professional Series PS77401 Chassis Replacement
必要な工具と部品
    1. Professional Series PS77401 Chassis Replacement, Shell: 手順 1、 1の画像 1
      • Make sure that the toaster is unplugged before attempting any sort of disassembly!
      FixBotに聞いてみる
      コメントを追加
    2. Professional Series PS77401 Chassis Replacement: 手順 2、 2の画像 1 Professional Series PS77401 Chassis Replacement: 手順 2、 2の画像 2
      • Grip the black plastic lever nub firmly and carefully remove it from the metal lever. Use one hand to hold the toaster in place while you pull the lever nub with the other.
      • If this is the first time detaching this piece, it will take some effort to remove. Be careful as pulling too hard can cause damage to the inner lever mechanism.
      FixBotに聞いてみる
      コメントを追加
    3. Professional Series PS77401 Chassis Replacement: 手順 3、 3の画像 1 Professional Series PS77401 Chassis Replacement: 手順 3、 3の画像 2 Professional Series PS77401 Chassis Replacement: 手順 3、 3の画像 3
      • Flipping the toaster upside down, use a T7 Torx Screwdriver to remove the four 10mm screws that keep the outer shell attached.
      • Flip the toaster back over and slide off the shell making sure to slip the toaster lever (now without the black plastic nub) through the lever opening in the shell.
      • The outer shell should now only be connected by its internal wiring.
      FixBotに聞いてみる
      コメントを追加
    4. Professional Series PS77401 Chassis Replacement: 手順 4、 2の画像 1 Professional Series PS77401 Chassis Replacement: 手順 4、 2の画像 2
      • Locate and remove the two 8mm screws that attach the circuit board (located inside of the shell) from the shell itself using the Phillips #2 screwdriver.
      • The shell should now be completely separated from the rest of the toaster.
      FixBotに聞いてみる
      コメントを追加
    1. Professional Series PS77401 Chassis Replacement, Chassis: 手順 5、 3の画像 1 Professional Series PS77401 Chassis Replacement, Chassis: 手順 5、 3の画像 2 Professional Series PS77401 Chassis Replacement, Chassis: 手順 5、 3の画像 3
      • Locate the small circuit board attached to the base of the toaster.
      • To remove the circuit board, pull apart the two side tabs while releasing the middle tab simultaneously.
      • Pull the circuit board out of the slot.
      FixBotに聞いてみる
      コメントを追加
    2. Professional Series PS77401 Chassis Replacement: 手順 6、 3の画像 1 Professional Series PS77401 Chassis Replacement: 手順 6、 3の画像 2 Professional Series PS77401 Chassis Replacement: 手順 6、 3の画像 3
      • Using a Phillips #2 screwdriver, remove the front two 8mm screws attaching the chassis to the base.
      • Flip the toaster around and proceed to remove the two remaining 8mm screws.
      • The toaster chassis should now only be connected to the base via wiring.
      FixBotに聞いてみる
      コメントを追加
    3. Professional Series PS77401 Chassis Replacement: 手順 7、 1の画像 1
      • There are two phillips 8mm head screws holding the power cable to the base.
      • Remove these screws to release the power cable.
      FixBotに聞いてみる
      コメントを追加
    4. Professional Series PS77401 Chassis Replacement: 手順 8、 2の画像 1 Professional Series PS77401 Chassis Replacement: 手順 8、 2の画像 2
      • The following wires must be disconnected to be able to remove the chassis: Blue x2, White x2, Bronze x1
      • Disconnecting the cables in the middle is recommended to be able to reconnect new wires from a new chassis easily.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
4人の作成者と共同で作成されました。
Kevin
メンバー登録日: 01/23/14
107 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 10-36, Maness Winter 2014 Cal Poly, Team 10-36, Maness Winter 2014人のメンバー
CPSU-MANESS-W14S10G36
4 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 28
今までの合計 1,396
