メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Prerequisite Lower Half Casing Disassembly
必要な工具と部品
    1. Prerequisite Lower Half Casing Disassembly, Exterior Housing: 手順 1、 3の画像 1 Prerequisite Lower Half Casing Disassembly, Exterior Housing: 手順 1、 3の画像 2 Prerequisite Lower Half Casing Disassembly, Exterior Housing: 手順 1、 3の画像 3
      この手順で使用する道具:
      iOpener
      $24.95
      • Pry the exterior housing off the iHome iP37. You may need extra leverage to do this.
      • Note: This step is the most difficult due to the way it is attached. The glue holding the exterior housing to the internals does not break easily. You may want to use iFixit's iOpener to soften the glue.
      • Note: The process is the same for both the upper half and the lower half. To identify the halves, look for these details: the upper half has a metal grid, and the lower half has buttons. If you are replacing any other components, pry off the lower half.
      FixBotに聞いてみる
      コメントを追加
    1. Prerequisite Lower Half Casing Disassembly, Lower Half Casing: 手順 2、 3の画像 1 Prerequisite Lower Half Casing Disassembly, Lower Half Casing: 手順 2、 3の画像 2 Prerequisite Lower Half Casing Disassembly, Lower Half Casing: 手順 2、 3の画像 3
      • Remove these four 9 mm screws from the plastic casing; you will need a Phillips #2 driver to do this.
      • Remove the flanged 9 mm screw from the counterweight; you will need a Phillips #2 driver to do this.
      • Lift and remove the counterweight.
      FixBotに聞いてみる
      コメントを追加
    2. Prerequisite Lower Half Casing Disassembly: 手順 3、 3の画像 1 Prerequisite Lower Half Casing Disassembly: 手順 3、 3の画像 2 Prerequisite Lower Half Casing Disassembly: 手順 3、 3の画像 3
      • Lift and remove the plastic casing.
      • Note: It is best to lift the casing starting from the side without the protruding 3.5mm audio port and power port.
      • Reminder: During this process, a rubber cover will likely be dislodged. Make sure to re-seat this cover on the small pegs before putting the plastic casing back on.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
4人の作成者と共同で作成されました。
Jerrell
メンバー登録日: 04/23/14
730 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 11-50, Amido Spring 2014 Cal Poly, Team 11-50, Amido Spring 2014人のメンバー
CPSU-AMIDO-S14S11G50
4 メンバー
26のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 14
過去 30 日: 42
今までの合計 623
