メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Preliminary Main Board Removal
必要な工具と部品
  1. Preliminary Main Board Removal, Exterior Housing: 手順 1、 3の画像 1 Preliminary Main Board Removal, Exterior Housing: 手順 1、 3の画像 2 Preliminary Main Board Removal, Exterior Housing: 手順 1、 3の画像 3
    この手順で使用する道具:
    iOpener
    $24.95
    • Pry the exterior housing off the iHome iP37. You may need extra leverage to do this.
    • Note: This step is the most difficult due to the way it is attached. The glue holding the exterior housing to the internals does not break easily. You may want to use iFixit's iOpener to soften the glue.
    • Note: The process is the same for both the upper half and the lower half. To identify the halves, look for these details: the upper half has a metal grid, and the lower half has buttons. If you are replacing any other components, pry off the lower half.
    FixBotに聞いてみる
    コメントを追加
  2. Preliminary Main Board Removal, Lower Half Casing: 手順 2、 3の画像 1 Preliminary Main Board Removal, Lower Half Casing: 手順 2、 3の画像 2 Preliminary Main Board Removal, Lower Half Casing: 手順 2、 3の画像 3
    • Remove these four 9 mm screws from the plastic casing; you will need a Phillips #2 driver to do this.
    • Remove the flanged 9 mm screw from the counterweight; you will need a Phillips #2 driver to do this.
    • Lift and remove the counterweight.
    FixBotに聞いてみる
    コメントを追加
  3. Preliminary Main Board Removal: 手順 3、 3の画像 1 Preliminary Main Board Removal: 手順 3、 3の画像 2 Preliminary Main Board Removal: 手順 3、 3の画像 3
    • Lift and remove the plastic casing.
    • Note: It is best to lift the casing starting from the side without the protruding 3.5mm audio port and power port.
    • Reminder: During this process, a rubber cover will likely be dislodged. Make sure to re-seat this cover on the small pegs before putting the plastic casing back on.
    FixBotに聞いてみる
    コメントを追加
  4. Preliminary Main Board Removal, Preliminary Main Board: 手順 4、 2の画像 1 Preliminary Main Board Removal, Preliminary Main Board: 手順 4、 2の画像 2
    • Remove the two 9 mm screws that hold the main printed circuit board onto the rest of the iP37; you will need a Phillips #2 driver to do this.
    FixBotに聞いてみる
    コメントを追加
  5. Preliminary Main Board Removal: 手順 5、 1の画像 1
    • Peel away the black tape covering the red wires that connect to the PCB.
    FixBotに聞いてみる
    コメントを追加
  6. Preliminary Main Board Removal: 手順 6、 1の画像 1
    • There is ribbon wiring under this PCB. Be careful not to damage it while removing the PCB.
    • Slowly lift the PCB away from the rest of the device
    • Remove the ribbon by first removing the brown insert piece from the connector on the button board
    • Pull the ribbon out of the connector on the button board by the blue tab.
    FixBotに聞いてみる
    コメントを追加
  7. Preliminary Main Board Removal: 手順 7、 1の画像 1
    • Carefully disconnect the white 11-pin connector from the main board.
    • Pull firmly on the connector and use a screwdriver to pry it slightly if necessary.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Jerrell
メンバー登録日: 04/23/14
730 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 11-50, Amido Spring 2014 Cal Poly, Team 11-50, Amido Spring 2014人のメンバー
CPSU-AMIDO-S14S11G50
4 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 24
今までの合計 1,001
