メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
PowerBook G3 Wallstreet Heat Shield Replacement
必要な工具と部品
    1. PowerBook G3 Wallstreet Heat Shield Replacement, Keyboard: 手順 1、 1の画像 1
      • Remove both expansion bay modules using the levers on the front of the computer.
      • Insert your index fingers inside the expansion bays and search for the two ribbed tabs on the underside of the upper case. The tabs are located near the bottom corners of the keyboard.
      • Pull the tabs toward yourself and the keyboard will pop up.
      FixBotに聞いてみる
      コメントを追加
    2. PowerBook G3 Wallstreet Heat Shield Replacement: 手順 2、 1の画像 1
      • Pull the keyboard forward to disengage the tabs holding it in back and rotate it toward you.
      • Rest the keyboard on the trackpad.
      FixBotに聞いてみる
      コメントを追加
      • This is a diagram of the ribbon clamp connectors you will disconnect in the next step.
      • 1) With your fingernails, grasp the locking bar on either side and pull up a small amount (about 1/16" or 2 mm).
      • 2) After disengaging the locking bar, slide the cable out of the connector.
      FixBotに聞いてみる
      コメントを追加
    3. PowerBook G3 Wallstreet Heat Shield Replacement: 手順 4、 1の画像 1
      • Disconnect the two keyboard connectors by disengaging the clamps and pulling the ribbons directly upward.
      FixBotに聞いてみる
      コメントを追加
    4. PowerBook G3 Wallstreet Heat Shield Replacement: 手順 5、 1の画像 1
      • Slide a spudger downward between each plastic strain relief cable and the wall of the case in order to bow out the cable beyond the small tab holding it in place.
      • Once the strain relief cables are free, lift the keyboard off.
      FixBotに聞いてみる
      コメントを追加
    5. PowerBook G3 Wallstreet Heat Shield Replacement: 手順 6、 1の画像 1
      • Your laptop should look approximately like this.
      FixBotに聞いてみる
      コメントを追加
    1. PowerBook G3 Wallstreet Heat Shield Replacement, Heat Shield: 手順 7、 1の画像 1
      • Remove the two Phillips screws from the heat shield.
      • One screw is shorter than the other. When putting the Wallstreet back together, this screw goes in the middle of the heat shield.
      FixBotに聞いてみる
      コメントを追加
    2. PowerBook G3 Wallstreet Heat Shield Replacement: 手順 8、 1の画像 1
      • Grasp the metal handle on the heat shield and pull up and toward yourself.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
iRobot
メンバー登録日: 09/24/09
1 ポイント
636のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 34
今までの合計 4,836
