はじめに
If you need to replace the grip of your Porter-Cable PCE211 impact wrench, follow this guide. You'll need to remove the grip to access the switch as well.
Be sure to turn off the device and unplug from the power source prior to beginning this repair.
必要な工具と部品
Using the Hex Security SAE 7/32", remove the four 10 mm socket screws at the base of the gearcase.
ある他の人がこのガイドを完成しました。
