メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Polaroid A10 Front/Back Camera Replacement
必要な工具と部品
    1. Polaroid A10 Front/Back Camera Replacement, Back Cover: 手順 1、 3の画像 1 Polaroid A10 Front/Back Camera Replacement, Back Cover: 手順 1、 3の画像 2 Polaroid A10 Front/Back Camera Replacement, Back Cover: 手順 1、 3の画像 3
      • Begin by having the side with volume and power button face up towards you.
      • Insert a plastic opening tool between the display and the back cover.
      • Once you have one plastic opening tool in, you can insert another one. While holding one in place, slide the other along the gap to release the tabs.
      • It is easier to remove the back cover, if the display screen is faced down.
      • The tabs must be released from all four sides before removing the back cover.
      FixBotに聞いてみる
      コメントを追加
    1. Polaroid A10 Front/Back Camera Replacement, Battery: 手順 2、 3の画像 1 Polaroid A10 Front/Back Camera Replacement, Battery: 手順 2、 3の画像 2 Polaroid A10 Front/Back Camera Replacement, Battery: 手順 2、 3の画像 3
      この手順で使用する道具:
      Plastic Cards
      $2.99
      • Begin by inserting the flat end of a spudger underneath the battery to separate the glue from the battery.
      • It is better to use a plastic card if you have one.
      • Gently lift up the battery as you continue to separate the glue from the battery.
      • Lift up just enough to see where the glue is, so that you don't bend the battery.
      • Once the glue has been separated, gently lift up the battery and you will notice two wires attached to the motherboard.
      FixBotに聞いてみる
      コメントを追加
    2. Polaroid A10 Front/Back Camera Replacement: 手順 3、 3の画像 1 Polaroid A10 Front/Back Camera Replacement: 手順 3、 3の画像 2 Polaroid A10 Front/Back Camera Replacement: 手順 3、 3の画像 3
      FixBotに聞いてみる
      コメントを追加
    3. Polaroid A10 Front/Back Camera Replacement: 手順 4、 1の画像 1
      • Gently lift the battery up and out of the device.
      FixBotに聞いてみる
      コメントを追加
    1. Polaroid A10 Front/Back Camera Replacement, Front/Back Camera: 手順 5、 1の画像 1
      • The camera head is located on the upper middle section of the device, close to the battery.
      FixBotに聞いてみる
      コメントを追加
    2. Polaroid A10 Front/Back Camera Replacement: 手順 6、 2の画像 1 Polaroid A10 Front/Back Camera Replacement: 手順 6、 2の画像 2
      • Start by locating the two left and right screws which hold the camera head in place.
      • Using the Phillip's 000 screwdriver, remove the two 7 mm screws located in the picture by rotating the screw counter-clockwise.
      FixBotに聞いてみる
      コメントを追加
    3. Polaroid A10 Front/Back Camera Replacement: 手順 7、 3の画像 1 Polaroid A10 Front/Back Camera Replacement: 手順 7、 3の画像 2 Polaroid A10 Front/Back Camera Replacement: 手順 7、 3の画像 3
      • Locate the camera ribbon cable that is connected to the motherboard.
      • With a spudger, remove the camera ribbon cable base from the motherboard connector.
      • With one finger, delicately remove the camera ribbon cable by sliding down.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
3人の作成者と共同で作成されました。
Shilpa Verma
メンバー登録日: 01/22/15
353 ポイント
3のガイドは作成済み
チーム
UW Tacoma, Team 3-3, Rose Winter 2015 UW Tacoma, Team 3-3, Rose Winter 2015人のメンバー
UWT-ROSE-W15S3G3
4 メンバー
12のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 33
今までの合計 532
