メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Philips DVP642 Motherboard Replacement
必要な工具と部品
    1. Philips DVP642 Motherboard Replacement, Top Panel: 手順 1、 2の画像 1 Philips DVP642 Motherboard Replacement, Top Panel: 手順 1、 2の画像 2
      • Remove four 7.5 mm Phillips screws on the both sides (2 on each side).
      • Remove five 7.5 mm Phillips screws on the back of the player.
      FixBotに聞いてみる
      コメントを追加
    2. Philips DVP642 Motherboard Replacement: 手順 2、 2の画像 1 Philips DVP642 Motherboard Replacement: 手順 2、 2の画像 2
      • Lift the top panel from the back and remove. It should come off without being forced. There is a lip near the front so you many need to slide the top panel back slightly to remove it.
      FixBotに聞いてみる
      コメントを追加
    1. Philips DVP642 Motherboard Replacement, Motherboard: 手順 3、 3の画像 1 Philips DVP642 Motherboard Replacement, Motherboard: 手順 3、 3の画像 2 Philips DVP642 Motherboard Replacement, Motherboard: 手順 3、 3の画像 3
      • Locate the first three ribbon wires.
      • Remove the ribbon wires by grasping firmly as near to the plastic head as possible and pulling.
      • Be firm, but gentle when pulling to avoid pulling the wires off the head.
      FixBotに聞いてみる
      コメントを追加
    2. Philips DVP642 Motherboard Replacement: 手順 4、 3の画像 1 Philips DVP642 Motherboard Replacement: 手順 4、 3の画像 2 Philips DVP642 Motherboard Replacement: 手順 4、 3の画像 3
      • Remove the fourth ribbon wire as in step 2.
      • Remove the fifth ribbon wire by grasping both sides of the black clip and pulling up. When reinserting, pull black clip up, insert the ribbon wire, and push the black clip back down.
      FixBotに聞いてみる
      コメントを追加
    3. Philips DVP642 Motherboard Replacement: 手順 5、 2の画像 1 Philips DVP642 Motherboard Replacement: 手順 5、 2の画像 2
      • Remove the following screws:
      • 7.5 mm Phillips screws (2) that secure the motherboard to the bottom panel. The screw on the top right will also be attached to a grounding wire, it is okay to remove this screw.
      • Remove the 7.5 mm Phillips screw on the bottom right that attaches the grounding wire to the disc tray.
      • 7.5 mm Phillips screws (4) on outside of player near input/output plugs.
      FixBotに聞いてみる
      コメントを追加
    4. Philips DVP642 Motherboard Replacement: 手順 6、 1の画像 1
      • Remove the motherboard by pulling it back and then up gently.
      • The input/output plugs should slide out easily from the holes in the back panel.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
6 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Nathan Klammer
メンバー登録日: 10/06/11
521 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 21-20, Maness Fall 2011 Cal Poly, Team 21-20, Maness Fall 2011人のメンバー
CPSU-MANESS-F11S21G20
4 メンバー
19のガイドは作成済み
1件のガイドコメント
Dvp3005/Ik mother bord .how much price
Md Younus - 返信 共有
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 17
過去 30 日: 63
今までの合計 12,504
