はじめに
The rubber dampers that cause slow or stuck mirrors are located in the mirror box mechanism. Fully disassembling the mirror box, cleaning problem areas, and installing new dampers is necessary to fully address the issue. The following guide details the disassembly process and how to get replacement dampers. It also recommends other general cleaning and maintenance to improve the performance of the mirror box mechanism.
Removing the flex PCB from the mirror box is recommended when servicing the mechanisms as it will reduce the risk of damaging the electronic components. Removing the focusing screen is also recommended.
Any disassembly of the LX body will compromise the weather sealing. New seals must be reapplied during final reassembly to restore weather proofing.
必要な工具と部品
Place a thin tool in the rewind fork and unscrew the topside knob.
Remove the washer under the rewind knob.
Remove three #000 5.5 mm screws.
Remove exposure compensation dial assembly.
Remove washer.
Remove rubber seal.
Use a piece of tape wrapped sticky side out to grip the winding lever cover. Turn clockwise to loosen and remove
Remove four #000 2.5 mm screws.
Use spanners to remove top cover retaining nut.
Gently remove the rubber covering around the shutter speed dial.
Remove three #000 1.6 mm screws.
Remove cover ring.
Remove one #00 2.5 mm screw.
Remove one #00 X mm screw.
Lift off top cover.
Remove the rubber bumper covering the screw.
Remove one #00 1.8 mm screw.
Repeat on the other side of the bottom plate (#00 3.0 mm screw).
Use isopropyl alcohol to soften the adhesive along the edge of the leatherette.
Use a dull spudger or scraper to peel off the covering.
Turn the self timer lever to the 9 o'clock position.
Loosen the entire right side leatherette in the same manner, then work it over and around the self timer lever to remove.
Remove the two cover plates under the leatherette.
They may stick to the covering adhesive and come off on their own.
This small plug may also be loose.
Unsolder one gray wire.
Unsolder two yellow wires.
Unsolder one blue wire.
Unsolder one red wire.
Unscrew four #00 X mm screws.
Unsolder one white wire.
Unsolder one pink wire.
Unsolder one light green wire.
Check the mounting points for shim washers. If they are loose, note the position and remove.
Unsolder one purple wire.
Unsolder one green wire.
Unsolder two brown wires under the loop of flex cable.
Unscrew three #00 3.0 mm screws.
Remove exp/ISO resistor assembly.
Remove exp. compensation coupling cam.
There are two loose ball bearings that sit in these holes. Do not lose.
Installation Note: Push this lever back to properly seat the exposure compensation lock. Check that the flag in the viewfinder is working properly. It should not be visible when dial is set to 1x and pop into view when set to any other value.
Unsolder five black wires.
Unsolder two green wires.
Unsolder one yellow wire.
Unsolder one orange wire.
Unsolder one light brown wire.
Unsolder one light blue wire (may appear beige).
Unsolder two black wires.
Unsolder one brown wire.
Unsolder one light blue/teal wire.
Turn shutter speed selector to 'Auto'.
Turn lock lever screw clockwise to loosen. Do not remove.
Push lock lever toward the needle indicator gear.
Turn lock lever screw counter-clockwise to tighten.
Remove two #00 2.8 mm screws. Remove two loose spacers underneath the PCB.
Remove two #00 2.0 mm screws.
Remove two #00 3.0 mm screws.
Remove one #00 5.0 mm screw.
Remove mirror box by lifting up then out. Pull slowly and check for snags as you remove.
Before installing the mirror box, the shutter should be wound and the mirror released into the taking position (up against the focusing screen).
After mounting the mirror box, make sure all necessary wires are available through the bottom of the camera for soldering.
Check for proper coupling of the self timer and the shutter button release.
Check that the closing curtain latch sits forward of the mirror return latch.
Check that the FP switch lever holds the magnet lever.
Select one of the mechanical shutter speeds and test the function of the mirror and shutter. The camera should be capable of a complete exposure cycle at this point.
SW g1: On when mirror is down. Off when mirror is up. Yellow to ground.
SW g2: Off when mirror is down. On when mirror is up. Blue to brown.
SW T: Off when mirror is down. On when mirror is up. Gray to top contact.
SW MDT: Off normally. On when shutter button is half pressed or when mirror is up. Orange to ground.
SW P: Off normally. On when shutter button is half pressed or when mirror is up. Red to blue.
SW FP: Off when mirror is down. On when mirror is up. White to ground.
SW MDS: Off when mirror is down. On when mirror is up. Green to ground.
This video shows a properly functioning mirror box mechanism for reference.
The release latch should move freely when the mechanism is not charged.
SW P, on the bottom of the mirror box, should close before the mirror is released.
Charge the mechanism by pulling the mirror return lever towards the back of the camera.
Push the mirror release lever down to flip the mirror up.
Pull the mirror return latch to flip the mirror down.
Remove one 1.9 mm #000 screw.
Use a u-bit driver to remove one nut.
Remove retainer plate.
Remove two shim washers.
Remove one 1.5 mm circlip and shim washer.
Remove aperture priority actuating lever.
Remove mirror release latch assembly.
The third image shows the stack up of components in the assembly, bottom to top. This can be quite difficult to get back together properly. It may be easier to reinstall it on the post piece by piece, rather than to install as a complete assembly.
Installation Notes: Make sure this arm of the latch sits to the right of the power switch lever. This is the mechanism that turns on the light meter when the shutter button is half-pressed. Also pay attention to the attachment points of the bias spring.
Unhook one end of the mirror flip-up spring. A piece of string or fishing line can be helpful.
Unhook the brake lever spring.
Remove one 3.0 mm flat head shoulder screw.
Remove one retaining ring. Circlip pliers are required.
Remove mirror actuating lever.
Remove one 3.4 mm #00 screw and shim washers.
Unhook bias spring.
Remove aperture actuating lever.
Remove one 3.8 mm #00 screw.
Remove retaining clip.
Remove spacer.
Remove brass sleeve.
Remove mirror flip-up lever.
Installation Notes: This lever is connected to the mirror seat with a geared interface. The exact position of the gear mesh needs to be replicated during reassembly, otherwise the mirror will not move through its full travel.
Remove one 4.2 mm flat head screw.
Remove one 4.1 mm flat head screw.
Installation Notes: When reassembled with new stop plate dampers, there should be a small gap between the tip of the mirror return lever and the end of the guide plate slot.
Unhook bias spring.
Remove one 1.5 mm circlip.
Swing lever out and lift off post.
Remove bias spring.
Use pliers to unhook the mirror return spring from the post.
Remove one 3.3 mm #00 screw.
Lift off the mirror return lever.
The mirror return lever has an old rubber damping pad on it that should be cleaned off and replaced.
Remove two 2.4 mm #00 screws.
On some LX models, the mirror return stop will also have a rubber damper here.
Thoroughly clean all removed parts with isopropyl alcohol.
Clean all posts and pivots on the mirror box.
Remove and replace all foam seals with new material.
Clean all electrical contacts with isopropyl alcohol and/or contact cleaner.
Remove the rubber damper from the mirror rest seat.
Remove second mirror rest. This is a rubber cap placed over a metal stud.
Further disassembly of the mirror box is possible but this is enough to remedy most issues. Reassemble in reverse order and check functionality along the way.
ある他の人がこのガイドを完成しました。
6件のガイドコメント
Thank you for the great work you've done! I'm having a couple issues on reassembly and I don't have any other bodies or references for this camera. The slow mirror problem seems to have appeared out of nowhere even though I replaced the bumpers with the ones from the STL. I initially opened it up to fix the always on meter. I believe it has to do with the aperture actuating lever, since there is still contact and friction between the bumper adjusting eccentric and the aperture mechanism. Perhaps the two circlips aren't positioned correctly, but I can't tell. The U bit retaining ring can lock up the whole mechanism of it's overtightened, and I don't think that's supposed to happen.
The strangest things that's happening is now that the slow mirror problem disappears if I point the camera down. It can be totally stuck when it's upright, then cycle just fine when I point it down. Any thoughts?
Feel free to message me on Reddit, u/jazimms if you want. I run a repair shop in South Florida but don't do a lot of LXs.
I wanted to know what hardness to use for printing the file on my Pentax LX Rubber Dampers TPU printer: Shore 90, 85, or less? Also, there are three print files; are they all the same or are there any modifications? Thank you very much in advance for helping me save my LX.
Nahuel Miras - 返信 共有
I would order the softest TPU that your printing service can make. I think I used 85 Shore A hardness and it was still quick stiff. The *.stl in the documents section is meant to be printed as a single body. Then the individual dampers can be snipped off of the "sprues". Some of the parts are printed in multiple sizes or thicknesses to make it easier to tune the mirror rest position. Is that what you were wondering about?
No, I understood that there were three STL file downloads for printing. I wanted to know if they were the same or different. I printed one set at 90 and another at 85 because I thought I'd make the one for the central axis (b38) harder and the ones (b115) softer since they dampen the mirror and give a 45-degree angle. Did you make them all the same hardness? Should I make them 75 then?
Hmm, I'm still not sure I understand what you mean by three STL downloads. I only see one file in the documents section and there is only one body in the STL file. I don't think you need to make the dampers with different hardness, though. The original dampers all look to be the same material. The ones you printed at 85 Shore A should work well.
