はじめに
The Parrot Hydrofoil Minidrone has four propellers located at each corner of the body. This guide will detail how to replace those components.
Locate the propellers of the same angle, each diagonally across from each other.
Locate the propellers of the opposite angle, located diagonally across from each other.
Grip each white propeller firmly and pull up to remove.
ある他の人がこのガイドを完成しました。
