メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Pantech Breakout Motherboard Replacement
必要な工具と部品
  1. Pantech Breakout Motherboard Replacement, Removing Back Cover: 手順 1、 3の画像 1 Pantech Breakout Motherboard Replacement, Removing Back Cover: 手順 1、 3の画像 2 Pantech Breakout Motherboard Replacement, Removing Back Cover: 手順 1、 3の画像 3
    • Before proceeding, completely power off phone and disconnect power cords to avoid electrical shock.
    • Turn phone over so that the back side is facing up.
    • Using a finger, apply moderate pressure to the top of the back cover while sliding the cover down and off.
    • Lift and remove the back cover from the phone.
    FixBotに聞いてみる
    コメントを追加
  2. Pantech Breakout Motherboard Replacement, Removing the Battery: 手順 2、 2の画像 1 Pantech Breakout Motherboard Replacement, Removing the Battery: 手順 2、 2の画像 2
    • Locate the battery: It is a silver, rectangular object.
    • Insert a fingernail into the indent just below the battery about 0.5 inches from the bottom of the phone.
    • Then, apply pressure to the battery, pushing up and away from the phone. It will come out easily.
    FixBotに聞いてみる
    コメントを追加
  3. Pantech Breakout Motherboard Replacement, Remove Screws: 手順 3、 1の画像 1
    • With the phone face down on a hard surface, locate the six 3.5mm Phillips screws around the perimeter of the phone.
    • Three of these screws are black, while three are silver.
    • Use a Phillips #00 or #000 screwdriver to remove all six Phillips screws.
    • Righty Tighty, Lefty Loosey!
    FixBotに聞いてみる
    コメントを追加
  4. Pantech Breakout Motherboard Replacement, Separating the Back Case: 手順 4、 2の画像 1 Pantech Breakout Motherboard Replacement, Separating the Back Case: 手順 4、 2の画像 2
    • Be careful when prying the plastic bezel and back case apart from each other; the parts are connected by both snaps and adhesive. Forcing the back case off could result in it breaking or cracking.
    • Slide a Plastic Opening Tool in between the front bezel and the back case, slowly working it around the tight edges.
    • Be patient, it may take several tries to remove the bezel and back case successfully. You may need to slide repeatedly along the edges of the entire phone perimeter to loosen the adhesive between the two pieces.
    FixBotに聞いてみる
    コメントを追加
  5. Pantech Breakout Motherboard Replacement, Removing Back Case: 手順 5、 2の画像 1 Pantech Breakout Motherboard Replacement, Removing Back Case: 手順 5、 2の画像 2
    • Starting at the charging port cover open by prying away from front face to remove back case.
    • Make sure that no part of the back case is caught on any other part of the phone; the USB charging port can get in the way.
    • After removing the bevel and back case of the phone, you will now see the motherboard and other internal components.
    FixBotに聞いてみる
    コメントを追加
  6. Pantech Breakout Motherboard Replacement, Component Board Separation: 手順 6、 3の画像 1 Pantech Breakout Motherboard Replacement, Component Board Separation: 手順 6、 3の画像 2 Pantech Breakout Motherboard Replacement, Component Board Separation: 手順 6、 3の画像 3
    • After removal of front bezel and back cover, locate and remove two Phillips #000 screws from the top corners of the phone.
    • After taking out the screws, lift off the black plastic piece containing the speaker, Micro SD card slot and SIM card slot.
    FixBotに聞いてみる
    コメントを追加
  7. Pantech Breakout Motherboard Replacement, Disconnecting Ribbon Cables: 手順 7、 3の画像 1 Pantech Breakout Motherboard Replacement, Disconnecting Ribbon Cables: 手順 7、 3の画像 2 Pantech Breakout Motherboard Replacement, Disconnecting Ribbon Cables: 手順 7、 3の画像 3
    この手順で使用する道具:
    • Locate the four ribbon connections near the top of the phone, above where the battery was.
    • Using a set of Tweezers, carefully pull each ribbon up from its connection. After this is complete, the motherboard will freely separate from the back of the screen.
    • Separate motherboard from screen.
    • The vibrator motor will be dangling from the motherboard by a wire, it is not detachable.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Ryan Murphy
メンバー登録日: 09/25/14
898 ポイント
7のガイドは作成済み
チーム
USF Tampa, Team 5-5, Mcgee Fall 2014 USF Tampa, Team 5-5, Mcgee Fall 2014人のメンバー
USFT-MCGEE-F14S5G5
4 メンバー
14のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 16
過去 30 日: 52
今までの合計 952
