メインコンテンツにスキップ
Panasonic Lumix DMC-ZS35 Motherboard Replacement
必要な工具と部品
  1. Panasonic Lumix DMC-ZS35 Motherboard Replacement, Back Casing: 手順 1、 3の画像 1 Panasonic Lumix DMC-ZS35 Motherboard Replacement, Back Casing: 手順 1、 3の画像 2 Panasonic Lumix DMC-ZS35 Motherboard Replacement, Back Casing: 手順 1、 3の画像 3
    • Remove the six 4mm screws located on the side and bottom of the camera casing using a Phillips #000 screwdriver.
  2. Panasonic Lumix DMC-ZS35 Motherboard Replacement: 手順 2、 2の画像 1 Panasonic Lumix DMC-ZS35 Motherboard Replacement: 手順 2、 2の画像 2
    • Use a plastic opening tool to carefully separate the back casing from the main body of the camera. It's advised to run along the entire "seam" of the casing and the camera with the tool to ensure full separation.
  3. Panasonic Lumix DMC-ZS35 Motherboard Replacement: 手順 3、 1の画像 1
    • Gently pry apart the back casing from the body of the camera. It's recommended to apply as minimal force as is necessary to prevent unintended damage to the camera or the casing.
  4. Panasonic Lumix DMC-ZS35 Motherboard Replacement, Screen: 手順 4、 2の画像 1 Panasonic Lumix DMC-ZS35 Motherboard Replacement, Screen: 手順 4、 2の画像 2
    • Unscrew the four 3mm screws holding the LCD screen hinge in place using a Phillips #000 screwdriver.
  5. Panasonic Lumix DMC-ZS35 Motherboard Replacement: 手順 5、 1の画像 1
    • Gently pull LCD screen ribbon cable from internal port to disconnect the screen and prevent unwanted damage.
    • Lift the freed LCD screen from the base camera to complete the process.
  6. Panasonic Lumix DMC-ZS35 Motherboard Replacement, Lens: 手順 6、 3の画像 1 Panasonic Lumix DMC-ZS35 Motherboard Replacement, Lens: 手順 6、 3の画像 2 Panasonic Lumix DMC-ZS35 Motherboard Replacement, Lens: 手順 6、 3の画像 3
    • Remove the four 2mm Phillips #000 screws on the sides of the exposed internal metal plate within the camera.
  7. Panasonic Lumix DMC-ZS35 Motherboard Replacement: 手順 7、 3の画像 1 Panasonic Lumix DMC-ZS35 Motherboard Replacement: 手順 7、 3の画像 2 Panasonic Lumix DMC-ZS35 Motherboard Replacement: 手順 7、 3の画像 3
    • Using an iFixit opening tool, gently remove the plating.
    • Carefully remove the ribbon cable connecting the plating with the lens component.
  8. Panasonic Lumix DMC-ZS35 Motherboard Replacement: 手順 8、 2の画像 1 Panasonic Lumix DMC-ZS35 Motherboard Replacement: 手順 8、 2の画像 2
    • Remove the 2mm screws holding the lens in place with a Phillips #000 screwdriver, located along the perimeter of the lens component within its housing.
  9. Panasonic Lumix DMC-ZS35 Motherboard Replacement: 手順 9、 2の画像 1 Panasonic Lumix DMC-ZS35 Motherboard Replacement: 手順 9、 2の画像 2
    • Carefully lift the lens component from the housing once it is freed.
    • Ensure that all connectors and cables are disconnected between the lens and other components before separation.
  10. Panasonic Lumix DMC-ZS35 Motherboard Replacement, Motherboard: 手順 10、 3の画像 1 Panasonic Lumix DMC-ZS35 Motherboard Replacement, Motherboard: 手順 10、 3の画像 2 Panasonic Lumix DMC-ZS35 Motherboard Replacement, Motherboard: 手順 10、 3の画像 3
    • Using the opening tool, gently pry off the mother board. Run the opening tool along the outer edges of the motherboard as necessary to loosen it until it is fully removed.
    • Be sure to disconnect all cables before separating the motherboard from the camera, either by disconnecting the ZIF connectors or soldering if necessary.
終わりに
作成者
3人の作成者と共同で作成されました。
Rachel Hughes
メンバー登録日: 01/31/20
688 ポイント
4のガイドは作成済み
チーム
UW Stout, Team S1-G2, Schneider-Bateman Spring 2020 UW Stout, Team S1-G2, Schneider-Bateman Spring 2020人のメンバー
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G2
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 8
今までの合計 143
