必要な工具と部品
Make sure your Palm Pre is turned off before disassembling the phone.
Snap off the back panel to reveal the battery.
Use the T5 Torx Screwdriver to remove the six screws holding the backing frame in place.
この手順で使用する道具:Tweezers$4.99
Remove the two ribbon cable connectors using tweezers.
Use tweezers to peal keyboard sensor starting from the bottom.
