はじめに
The PDP Rematch's vibration motors should be replaced if they are damaged and stopped working. To access the vibration motors, separate the front housing shell and the back shell of the controller.
必要な工具と部品
Orient the controller so the back side is facing up.
Use a Phillips #000 screwdriver to remove the seven 9 mm screws that secure the back shell.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
ある他の人がこのガイドを完成しました。
