メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Overclocking your eMac
必要な工具と部品
  1. Overclocking your eMac, Door Removal: 手順 1、 3の画像 1 Overclocking your eMac, Door Removal: 手順 1、 3の画像 2 Overclocking your eMac, Door Removal: 手順 1、 3の画像 3
    • It should be noted that these guides are written based on a late-model eMac (2005, 1.42GHz, DDR). They will differ slightly from the older model eMacs that use PC-133 RAM.
    • Lay the eMac screen-down on a flat surface. I've found it convenient to use a carpeted floor because the computer is so heavy.
    • Remove the single phillips #2 screw on the RAM door, and remove the door
    • The screw is captive in the door, so don't worry about losing it.
    FixBotに聞いてみる
    コメントを追加
  2. Overclocking your eMac, Bottom Screw Removal: 手順 2、 1の画像 1
    • Before starting this process it's important to note that the eMac can have some seriously dangerous voltages inside of it, thanks to the CRT display. Before working on an eMac, you should unplug it, press the power button to clear any stored charge on the motherboard, and then let it sit for 24-hours (or more) to allow the CRT to discharge.
    • You can read more about CRT safety procedures here. If you aren't experienced with working on devices featuring a CRT, it's recommended that you don't proceed any further.
    • On the bottom side of the eMac, remove the following screws:
    • A single 2.5mm hex screw
    • Two #2 phillips screws
    FixBotに聞いてみる
    コメントを追加
  3. Overclocking your eMac, Top and Side Screws: 手順 3、 3の画像 1 Overclocking your eMac, Top and Side Screws: 手順 3、 3の画像 2 Overclocking your eMac, Top and Side Screws: 手順 3、 3の画像 3
    • Remove two 2.5mm hex screws from each of the other sides of the computer.
    FixBotに聞いてみる
    コメントを追加
  4. Overclocking your eMac, Power Button Cable: 手順 4、 2の画像 1 Overclocking your eMac, Power Button Cable: 手順 4、 2の画像 2
    • Now, the shell can almost be separated from the computer.
    • There is a cable that connects to the power button. This must be disconnected before removing the housing completely.
    • Lift the housing enough to allow you to fit your hand through the access door, and disconnect the cable at the power button.
    FixBotに聞いてみる
    コメントを追加
  5. Overclocking your eMac, Shell Removal: 手順 5、 1の画像 1
    • Now the entire shell can be removed from the computer.
    FixBotに聞いてみる
    コメントを追加
  6. Overclocking your eMac, Panel Removal: 手順 6、 3の画像 1 Overclocking your eMac, Panel Removal: 手順 6、 3の画像 2 Overclocking your eMac, Panel Removal: 手順 6、 3の画像 3
    • The motherboard access panel is held on by 4 phillips #2 screws.
    • Remove the screws, then use your fingers to pull on the top tabs to separate the panel from the computer frame.
    FixBotに聞いてみる
    コメントを追加
  7. Overclocking your eMac, Cables: 手順 7、 3の画像 1 Overclocking your eMac, Cables: 手順 7、 3の画像 2 Overclocking your eMac, Cables: 手順 7、 3の画像 3
    • To remove the fan assembly, several cables must be disconnected first:
    • 3-pin fan cable
    • Ground wire, requires phillips #2 screwdriver
    • 2-pin AC cable to power supply
    FixBotに聞いてみる
    コメントを追加
  8. Overclocking your eMac, Screws: 手順 8、 2の画像 1 Overclocking your eMac, Screws: 手順 8、 2の画像 2
    • Now remove the following screws securing the fan assembly:
    • 3x coarse thread phillips #2
    • 1x machine thread phillips #2
    FixBotに聞いてみる
    コメントを追加
  9. Overclocking your eMac: 手順 9、 1の画像 1
    • There may be a zip tie holding another cable to the fan assembly, cut it to remove the fan assembly.
    FixBotに聞いてみる
    コメントを追加
  10. Overclocking your eMac, Assembly Removal: 手順 10、 2の画像 1 Overclocking your eMac, Assembly Removal: 手順 10、 2の画像 2
    • You should now be able to remove the fan assembly.
    • Doing this will expose more of the CRT neck, be careful not to touch this area because it can contain high voltages (and is fragile)
    FixBotに聞いてみる
    コメントを追加
  11. Overclocking your eMac, Bottom Connectors: 手順 11、 1の画像 1
    • There are four connectors at the bottom of the motherboard that must be removed.
    FixBotに聞いてみる
    コメントを追加
  12. Overclocking your eMac, Display Connector: 手順 12、 3の画像 1 Overclocking your eMac, Display Connector: 手順 12、 3の画像 2 Overclocking your eMac, Display Connector: 手順 12、 3の画像 3
    • There is a large display connector that must be removed. This can be done by squeezing the tabs and pulling.
    FixBotに聞いてみる
    コメントを追加
  13. Overclocking your eMac, Power Button Cable: 手順 13、 1の画像 1
    • The power button cable may be tucked in the casing, you will need to un-tuck it.
    FixBotに聞いてみる
    コメントを追加
  14. Overclocking your eMac, Screws: 手順 14、 3の画像 1 Overclocking your eMac, Screws: 手順 14、 3の画像 2 Overclocking your eMac, Screws: 手順 14、 3の画像 3
    • There are several phillips #2 screws that hold the eMac motherboard assembly to the rest of the computer. They will all need to be removed.
    • 2 large ones near the drive bay door.
    • 7 smaller ones scattered around
    FixBotに聞いてみる
    コメントを追加
  15. Overclocking your eMac, Screws (Continued): 手順 15、 2の画像 1 Overclocking your eMac, Screws (Continued): 手順 15、 2の画像 2
    • More of the screw locations from the previous step
    FixBotに聞いてみる
    コメントを追加
  16. Overclocking your eMac, Motherboard Assembly: 手順 16、 1の画像 1
    • The motherboard assembly should now come free.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Emmanouil Georgopoulos
メンバー登録日: 03/15/11
115 ポイント
1ガイドが承認済み
2件のガイドコメント
i am searching a POWER BUTTON for my old eMac(2004)
somebody can help me?
my email:cabanel.robert@orange.fr
thank you!
capitaine NEMO - 返信 共有
Where is Overclocking ?)
Pavel - 返信 共有
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 14
過去 30 日: 66
今までの合計 2,797
