メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Oppo X9000 Power Button Replacement
必要な工具と部品
  1. Oppo X9000 Power Button Replacement, Removing the Back Cover: 手順 1、 2の画像 1 Oppo X9000 Power Button Replacement, Removing the Back Cover: 手順 1、 2の画像 2
    • Turn the phone over so that you are facing the back side of the phone.
    • With your fingers, pry the back cover up starting from the top of the phone near the headphone jack and camera.
    • Completely remove the back cover by moving down the sides and bottom with your fingers.
    FixBotに聞いてみる
    コメントを追加
  2. Oppo X9000 Power Button Replacement, Removing the Battery: 手順 2、 1の画像 1
    • With your finger, remove the battery from the phone by gently lifting the top-right corner nearest to the camera.
    FixBotに聞いてみる
    コメントを追加
  3. Oppo X9000 Power Button Replacement, Remove the Back Panel Screws: 手順 3、 2の画像 1 Oppo X9000 Power Button Replacement, Remove the Back Panel Screws: 手順 3、 2の画像 2
    • Remove the twelve exposed 3.6 mm Phillips screws on the rear of the phone using the 3.6 mm Phillips screwdriver.
    • Store all the screws in a safe place where you will not lose them.
    FixBotに聞いてみる
    コメントを追加
  4. Oppo X9000 Power Button Replacement, Remove the Rubber Stoppers: 手順 4、 2の画像 1 Oppo X9000 Power Button Replacement, Remove the Rubber Stoppers: 手順 4、 2の画像 2
    • Remove the three circular rubber screw covers on the back of the phone by slipping the spudger into the border between the rubber cover and the chassis. In one motion, pry the stopper out of the hole. This can take some force.
    FixBotに聞いてみる
    コメントを追加
  5. Oppo X9000 Power Button Replacement, Remove the Newly Exposed Screws: 手順 5、 1の画像 1
    • With the 3.6 mm Phillips screwdriver, remove the three newly exposed 3.6mm Phillips screws.
    FixBotに聞いてみる
    コメントを追加
  6. Oppo X9000 Power Button Replacement, Lift off the Back Panel: 手順 6、 2の画像 1 Oppo X9000 Power Button Replacement, Lift off the Back Panel: 手順 6、 2の画像 2
    • Insert the plastic opening tool underneath the chassis near the power button and pry the chassis from the phone. This should take a little force.
    FixBotに聞いてみる
    コメントを追加
  7. Oppo X9000 Power Button Replacement, Remove the Power Button Bracket: 手順 7、 1の画像 1
    • Use the sharp end of the spudger to pry the power button bracket from the side of the rear case.
    FixBotに聞いてみる
    コメントを追加
  8. Oppo X9000 Power Button Replacement, Let the Button Fall Out: 手順 8、 1の画像 1
    • Rotate the phone onto its side so that the power button falls out with ease.
    • Make sure not to lose the power button.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
4 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Joe Hanacek
メンバー登録日: 10/14/14
562 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 4-45, Amido Fall 2014 Cal Poly, Team 4-45, Amido Fall 2014人のメンバー
CPSU-AMIDO-F14S4G45
5 メンバー
32のガイドは作成済み
1件のガイドコメント
I am having trouble with my buttons as they no long spring back after i replaced the speaker. They now just sit flush with the body of the phone, both buttons and metal brackets are installed.
Any ideas?
Jake Karp - 返信 共有
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 10
過去 30 日: 42
今までの合計 4,166
