メインコンテンツにスキップ
Opening Procedure
必要条件のみ
この修理ガイドは、他のガイドの前提条件として使用されます。それ自体は不完全で、単独で使用されることはありません。
必要な工具と部品
  1. Opening Procedure, Pentalobe Screws: 手順 1、 1の画像 1
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.5 mm pentalobe screws from the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. Opening Procedure, Opening Procedure: 手順 2、 1の画像 1
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the iPhone for about 90 seconds in order to soften up the adhesive underneath.
  3. Opening Procedure: 手順 3、 2の画像 1 Opening Procedure: 手順 3、 2の画像 2
    • Apply a suction cup to the lower half of the front panel, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
  4. Opening Procedure: 手順 4、 3の画像 1 Opening Procedure: 手順 4、 3の画像 2 Opening Procedure: 手順 4、 3の画像 3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Insert an opening pick or other thin pry tool a few millimeters into the gap.
    • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
  5. Opening Procedure: 手順 5、 3の画像 1 Opening Procedure: 手順 5、 3の画像 2 Opening Procedure: 手順 5、 3の画像 3
    • Slide your pick around the corner and up the left edge of the phone, moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
    • Stop near the top left corner of the display.
  6. Opening Procedure: 手順 6、 3の画像 1 Opening Procedure: 手順 6、 3の画像 2 Opening Procedure: 手順 6、 3の画像 3
    • Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive.
    • Don't insert the pick very far, or you may damage the display cables along this side of the iPhone. Insert it only a few millimeters, or about the width of the display bezel.
  7. Opening Procedure: 手順 7、 1の画像 1
    • Gently pull up on the suction cup to lift up the bottom edge of the display.
    • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
  8. Opening Procedure: 手順 8、 1の画像 1
    • Pull on the small nub on the suction cup to remove it from the front panel.
  9. Opening Procedure: 手順 9、 3の画像 1 Opening Procedure: 手順 9、 3の画像 2 Opening Procedure: 手順 9、 3の画像 3
    • Slide an opening pick underneath the display along the top edge of the phone to loosen the last of the adhesive.
  10. Opening Procedure: 手順 10、 2の画像 1 Opening Procedure: 手順 10、 2の画像 2
    • Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
  11. Opening Procedure: 手順 11、 3の画像 1 Opening Procedure: 手順 11、 3の画像 2 Opening Procedure: 手順 11、 3の画像 3
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
終わりに
作成者
6人の作成者と共同で作成されました。
Jeff Suovanen
メンバー登録日: 08/06/13
428,122 ポイント
259のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
16,817のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 332
