メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
OontZ Angle 3 Motherboard Replacement
必要な工具と部品
    1. OontZ Angle 3 Motherboard Replacement, Back Case: 手順 1、 3の画像 1 OontZ Angle 3 Motherboard Replacement, Back Case: 手順 1、 3の画像 2 OontZ Angle 3 Motherboard Replacement, Back Case: 手順 1、 3の画像 3
      • Make sure that the OontZ Angle 3 is powered off before starting the disassembly.
      • Use the plastic opening tool to remove the rubber caps from each end of the speaker.
      FixBotに聞いてみる
      コメントを追加
    2. OontZ Angle 3 Motherboard Replacement: 手順 2、 1の画像 1
      • Remove four (4) 11.7 mm Phillips #0 screws from each side at the bottom of the speaker.
      FixBotに聞いてみる
      コメントを追加
    3. OontZ Angle 3 Motherboard Replacement: 手順 3、 2の画像 1 OontZ Angle 3 Motherboard Replacement: 手順 3、 2の画像 2
      • Use the plastic opening tool on one of the corners to separate the bottom piece from the speaker, and then remove the piece.
      FixBotに聞いてみる
      コメントを追加
    1. OontZ Angle 3 Motherboard Replacement, Motherboard: 手順 4、 3の画像 1 OontZ Angle 3 Motherboard Replacement, Motherboard: 手順 4、 3の画像 2 OontZ Angle 3 Motherboard Replacement, Motherboard: 手順 4、 3の画像 3
      • Locate the soldering connections for the battery on the motherboard and the wires for the speakers.
      • Use the soldering iron to disconnect the battery wires from the motherboard.
      • Use the soldering iron to disconnect the speaker wires from the motherboard.
      • When reconnecting the battery and speakers to the new motherboard, be careful to make the connections to the correct nodes as well as establish a complete connection, as the speakers could break with an incorrect connection and the battery risks overheating or erupting in flames if corrected incorrectly or poorly.
      FixBotに聞いてみる
      コメントを追加
    2. OontZ Angle 3 Motherboard Replacement: 手順 5、 3の画像 1 OontZ Angle 3 Motherboard Replacement: 手順 5、 3の画像 2 OontZ Angle 3 Motherboard Replacement: 手順 5、 3の画像 3
      • Remove the three (3) 3.6mm screws using a Phillips #0 screwdriver.
      • Use the plastic opening tool about midway down one side of the motherboard to pry it out of the casing.
      • Remove the faulty motherboard.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
9 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Mason Hollander
メンバー登録日: 01/20/16
1,604 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 15-6, Remmell Spring 2016 USF Tampa, Team 15-6, Remmell Spring 2016人のメンバー
USFT-REMMELL-S16S15G6
4 メンバー
12のガイドは作成済み
15件のガイドコメント
where do i buy mother board of oontz angle 3?
Jomar Agcaoili - 返信 共有
how much does a new motherboard cost??
Linda Coppola - 返信 共有
Can you post where to get a new MB?
Brian Dickert - 返信 共有
It does require a part...the new motherboard!
I'm having a hard time tracking down motherboards too. But the guide is still helpful if someone wants to harvest a motherboard out of another broken Oontz and use it in their own. If anyone else finds a source for the motherboard, feel free to edit the guide and include a link to it in the details section. Maybe if we all work together we can find a source.
Kelsea Weber - 返信 共有
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 20
過去 30 日: 58
今までの合計 13,950
