はじめに
このガイドでは、電源ボタンと音量ボタンの取り外し方を説明します。このガイドを使用して、どちらか一方、または両方を交換することができます。
一部のガイド画像では、バッテリーと背面カメラモジュールがすでにデバイス本体から取り外されています。この手順ではこれらを取り外す必要はありません。
必要な工具と部品
SIMカード取り出しツール、ビット、またはまっすぐに伸ばしたクリップを、SIMカードトレイの下にある小さな穴に挿入します。
しっかりと押し込んでトレイを取り出します。
デバイス下端にあるUSB-Cポートの両側に留められた、2本の長さ2.6 mm T2ネジを外します。
What are the reference of the screws ? They are missing in the one I bought !
Hi Yôken,
They help hold the back cover on. Most of the time, the clips are enough to hold the phone together.
Just FYI, for whatever reason my brand new OnePlus 5 had 0,8 mm stars screws instead of T2 Torx.
strixaluco - 返信
Definitely T2 for me. Do watch out during assembly. I have a feeling that it’s easy to strip these.
T2 for me too. It was missing in my kit and iFixit sent it later when I asked them about it.
吸盤カップをディスプレイの下端付近に装着します。
安定した強い力で吸盤を上方に引っ張ります。
オープニングツールの先端を吸盤近くのフレームの継ぎ目にまっすぐ押し込み、エッジがプラスチックフレームとバックカバー先端の間に挟まるようにします。
I found the suction cup to be more of a hindrance and kept hitting the power button, making it necessary to stop and turn the phone off again. I watched a youtube video where the person didn't use a suction cup at all and decided to try that. I also found that a guitar pick type spudger worked far better than the one shown in the picture. If you're having trouble getting it started, I suggest trying those two things.
オープニングツールの端が所定の位置に固定されたら、ツールをデバイス下端に沿って慎重にスライドさせます。
ツール先端端をデバイスの縫い目の内側に保ちながら、開口工具を携帯電話の左隅に注意深くスライドします。
This was extremely difficult & took a lot of force. I needed a thin flat metal spudger and wrecked a couple of plastic ones in the process. I left a few scratches along the join in the process. It would be easier if I had something to hold the phone, in my hand I kept turning it on by accident.
what was the metal spudger did you use? I am having trouble as well. I cannot seem to pry the back cover and it feels like it is shut tightly, there are no crevices I can pry into. What was your strategy may I ask?
At first, I slightly opened the body with a plastic tool, but it was not enough to actually open the back cover. Then I used a thin metal screwdriver for this. It was difficult but nothing special. Just be sure that you are opening the correct seam between the body and the screen and don’t make sudden moves. I bent nothing, everything came back in place when reassembled.
ivan -
Same as David here: the plastic opening tools/guitar picks were doing nothing (not even creating the first "crack") . In the end I managed to open it using Jimmy (the metal knife/spudger), but not without scratching the whole metal cover.
デバイス下端と左端が解放された状態で、フレームを軽く動かして上端と右端のクリップを外します。
フレームの上端をバックカバーに合わせ、上部のクリップが所定の位置にはまることを確認します。
デバイス長辺側に沿ってしっかりと握り、残りのクリップを所定の位置にはめ込みます。
Reinstalling the back cover stumped me for a second… If you’re struggling with aligning the top edge of the frame, remember that the camera is going to look off/pointed a bit too low until you actually clip the frame back in.
Really stupid but it was the only thing that tripped me up in this guide.
スパジャーの先でバックカバーフレックスケーブルをこじ り上げ、ソケットから外します。
If the flex cable pins are damaged, the flex cable can be replaced.
If the connecter pins (on the motherboard) are damaged, you might need to do microsoldering (or contact a microsoldering company) to replace the damaged connector.
Brendan -
スパッジャー先端で相互接続フレックスケーブルをこじ上げ、ソケットから外します。
This step is used in multiple guides, and not all of them require the cable to be bent away. You can just leave it sitting there, disconnected.
This image seems to show the daughterboard removed but there is no corresponding previous step. I see no way to remove the interconnect flex cable without removing the daughterboard. Possibly the volume switch can be removed with the cable still connected but I'm not confident enough to try this so will remove the daughterboard.
David,
Thanks for bringing this up. That's indeed a procedural error! I've added the missing steps in the affected guides.
スパッジャーの先端を使って、マザーボードの底部端付近のソケットからディスプレイインターコネクトケーブルを持ち上げて、接続を外します。
Hallo, hier scheint der Schritt zu fehlen, in dem das Kameramodul entfernt wird.
Hello Norman,
You do not need to remove the camera module for procedure.
Hi Arthur,
You do need to remove the camera module, it’s in the photographs above, but not from step 33 onwards. It needs removing in order to remove the motherboard in steps 34 and 35.
Hi Alex! Thanks for the feedback! Can you relay which replacement guide you found the missing steps in? That would help me very much!
There are no steps 33, 34, 35 in this guide so the above comments must be from some other guide. With this phone I just lifted out the motherboard, carrying the camera with it. It went back the same way - but be careful not to trap the connector cable at the front under it.
振動モーターの上のマザーボードに接続されているアンテナ相互接続ケーブルの下に、スパッジャーの先端を滑らせます。
こじ上げてケーブルをソケットから外します。
マザーボードのアースクリップからケーブルを外し、邪魔にならない場所に移動します。
Be attentive when reassembling if your unit doesn’t have a tape, which keeps antenna interconnect cable in place — I’ve accidentally got it squeezed with back cover.
strixaluco - 返信
マザーボードの上端近くに接続されている小さな四角いアンテナコネクターの下に、スパッジャーの先を滑らせます。
こじ上げて、アンテナコネクタをソケットから外します。
camera step seem to be missing
The cameras should be removed in step 14.
指を使って、マザーボードの上端を持ち上げます。
奥からマザーボードを持ち上げて外します。
The previous steps have not removed the camera although the pictures show it has been removed. I found that I could carefully lift away the motherboard with the camera attached.
When replacing the motherboard take care not to trap the small square antenna connector under the top edge.
この手順で使用する道具:Electrical Tape in 6 Assorted Colors$7.99
デバイス右端にある音量ボタンを覆っている黒いテープを、ピンセットまたはスパッジャーの先端でこじ開け、取り外します。
デバイス左端にある電源ボタンを覆っている黒いテープで、この手順を繰り返します。
この手順で使用する道具:Tesa 61395 Tape$5.99
ピンセットの先端を合わせ、フレームの右上端にある音量ボタンボードのコンタクトパッドの下に差し込みます。
上方にこじ開けると、フレームからコンタクトパッドが緩みます。
音量ボタンを外します。
Installing a vol button to a used frame I found the existing adhesive (a black sticky rubbery compound) still sticky enough to hold all in place except for the last 2mm of the outer strip with the switches which I fixed with a tiny piece of double sided tape. The tape was not at all adhesive & it's not obvious what it's for. Electric tape doesn't stick to the vol button strip so I used 2 or 3 pin prick size dots of contact adhesive to keep it in place. Fingers crossed!
デバイスを再組み立てするには、これらのインストラクションを逆の順番に従って作業を進めてください。
修理がうまく進みませんか?ベーシックなトラブルシューティングを試してみるか、OnePlus 5のアンサーコミュニティを参照してください。
6 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
翻訳を始める ›
2 件のコメント
I’ve just spent the afternoon migrating to a new frame, and the power button seating lugs were just a tiny bit mislocated. The result was permanent press on the power button when the back was fitted. I resolved this by trimming the power button circuit board with some sharp sidecutters. Charging now and seems ok. Would have been much harder without my ifixit toolkit.
Fantastic guide! Thanks! Some steps were slightly different for my OnePlus 5T but still quite helpful! I used it to replace the power button that was barely working.
Unfortunately it seems my replacement part had maybe slightly different tolerances and the button was being pressed permanently. I managed to fix it by very carefully shaving off a little bit of the case's mechanism that presses the button.
