Insert a SIM eject tool, bit, or straightened paperclip into the hole located between the SIM card slot and the power button.
Press firmly to eject the SIM card tray.
During reinstallation, make sure that the SIM card tray is properly oriented. It fits in only one direction.
There is a high risk of damaging the display panel if this opening procedure is improperly followed.
The following three steps show how to pry the rear case from the plastic frame. Read through the steps first before attempting the procedure.
There are two different seams between the screen and the body of the phone:
Display panel seam : This seam is part of the display assembly. Do not pry at this seam, or you will separate and damage the display panel.
Frame seam : This is where the plastic frame meets the back cover. It is recessed into the back cover. Only pry at this seam.
There are fourteen clips that hold the frame against the rear case. Be aware of their location as you pry the back cover off in the following steps.
As you work, try not to accidentally power on the phone. If you do, turn the phone off before resuming disassembly.
Place a suction cup near the bottom edge of the display.
Pull on the suction cup with strong steady force.
Press the edge of an opening tool straight into the frame seam near the suction cup until the edge wedges between the plastic frame and the back cover's lip.
Due to tight tolerances, this will take substantial force. Using a new opening tool with an unmarred edge will help with this step.
Do not use metal tools, as they will most likely crack the screen.
Once the opening tool's edge is wedged in position, carefully slide the tool along the bottom edge of the phone.
Carefully guide the opening tool around the left corner of the phone while keeping the tool's edge within the seam.
Continue sliding the opening tool along the long edge, releasing the clips along the way.
The last clip in the top-left corner near the alert switch is recessed and can be difficult to release. Take your time and use the flat end of a spudger or an opening pick to help.
With the bottom and left edge of the phone freed, gently wiggle the frame to release the top and right edge clips.
Lift the screen up and remove it.
During reassembly, pause here to test your phone's functionality before securing the back cover.
To reinstall the back cover:
Align the top edge of the frame to the back cover and ensure that the top clips slip into place.
Squeeze along the long edges of the phone to snap the remaining clips into place.
スパッジャーの先端を使って、バッテリーパックの上部右端の上に付いているバッテリーコネクタを引き上げて、接続を外します。
アクシデントで接触しないように、ソケットからコネクタを折り曲げます。
このようなプレスコネクタ を再度取付けする際は、所定の位置に装着するまで、片側を慎重に位置合わせしてカッチと音がするまで押し下げます。反対側も同じ作業を繰り返します。 中央部分は押さないでください。 コネクタの位置がずれていると、ピンが曲がってしまい、永久的な損傷を引き起こす可能性があります。
Use the point of a spudger to pry up and disconnect the interconnect flex cable from the motherboard, which is located above the battery.
Repeat the process to disconnect the daughterboard flex cable from the motherboard.
Remove the seven Phillips screws securing the motherboard to the frame:
Four 3 mm black screws
Three 2.9 mm silver screws
Some of these screws may be covered by stickers. Remove the stickers to access the screws.
Make sure you have ejected the SIM tray before performing this step.
The motherboard is still held in place near the top by clips.
Slide the flat end of a spudger underneath the top left corner of the motherboard.
Twist the spudger and pry up to release the motherboard from its recess.
railgunさんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか? 翻訳を始める ›
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
1つの手順
全ガイド
小サイズ - 600px
中サイズ - 800px
大サイズ - 1200px
プレビュー
