はじめに
This guide will show you how to replace a battery that no longer works. This is a common problem with any electronic device and is an easy fix. Just remember to turn the power off before you begin, and to be gentle with the battery. A damaged battery could catch on fire or explode.
必要な工具と部品
この手順で使用する道具:Tweezers$4.99
Desolder the red(+) and black(-) wires connecting the battery to the motherboard using a soldering iron and tweezers to hold the wire.
ある他の人がこのガイドを完成しました。
