はじめに
Removing the back case from the speaker is relatively easy. Once you unscrew the four back screws, there is a wire that is attached to the back case. Before pulling the back case completely off, disconnect the wire from the back case by carefully pulling it out with tweezers. This will allow the back case to be completely removed from the device.
必要な工具と部品
Flip the device over so the front of the speaker is facing down. Make sure to place the speaker on a flat surface
3 の人々がこのガイドを完成させました。
