メインコンテンツにスキップ
Nook Simple Touch with GlowLight Charging Port Replacement
必要な工具と部品
  1. Nook Simple Touch with GlowLight Charging Port Replacement, Power Button: 手順 1、 1の画像 1
    • Place the Nook with the screen facing down.
  2. Nook Simple Touch with GlowLight Charging Port Replacement: 手順 2、 1の画像 1
    • Wedge the opening tool between the power button and the upper edge of the device.
    • Push the opening tool down to pry the power button up.
  3. Nook Simple Touch with GlowLight Charging Port Replacement: 手順 3、 1の画像 1
    • Using your fingers, gently remove the power button.
  4. Nook Simple Touch with GlowLight Charging Port Replacement, Back Cover: 手順 4、 1の画像 1
    • Remove the single screw using a T4 Torx screwdriver.
  5. Nook Simple Touch with GlowLight Charging Port Replacement: 手順 5、 1の画像 1
    • Slide the back cover down towards you in the direction of the charging port.
  6. Nook Simple Touch with GlowLight Charging Port Replacement, Battery: 手順 6、 2の画像 1 Nook Simple Touch with GlowLight Charging Port Replacement, Battery: 手順 6、 2の画像 2
    • Detach the white cable connector from the motherboard.
    • Remove the battery from the device.
  7. Nook Simple Touch with GlowLight Charging Port Replacement, Motherboard: 手順 7、 1の画像 1
    • Remove eleven screws from the motherboard using the T4 screwdriver.
  8. Nook Simple Touch with GlowLight Charging Port Replacement: 手順 8、 3の画像 1 Nook Simple Touch with GlowLight Charging Port Replacement: 手順 8、 3の画像 2 Nook Simple Touch with GlowLight Charging Port Replacement: 手順 8、 3の画像 3
    • Disconnect the orange ribbon cable from the motherboard.
    • Using your fingers, gently lift the motherboard from the display.
  9. Nook Simple Touch with GlowLight Charging Port Replacement, Charging Port: 手順 9、 1の画像 1
    • Flip the motherboard over and locate the charging port.
  10. Nook Simple Touch with GlowLight Charging Port Replacement: 手順 10、 1の画像 1
    • Using a soldering iron, disconnect the charging port from the motherboard.
    • Use the soldering iron to attach the new charging port to the motherboard.
    • Be careful with the soldering iron - it is very hot and can damage your hands or the device.
終わりに
作成者
3人の作成者と共同で作成されました。
Sydney Segear
メンバー登録日: 03/01/23
401 ポイント
4のガイドは作成済み
チーム
University of Delaware, Team 12-3, McGuire Spring 2023 University of Delaware, Team 12-3, McGuire Spring 2023人のメンバー
UD-MCGUIRE-S23S12G3
5 メンバー
5のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 316
