メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Nokia XL Dual Sim Front Camera Replacement
必要な工具と部品
  1. Nokia XL Dual Sim Front Camera Replacement, Back Cover Removal: 手順 1、 1の画像 1
    • You will first need to separate the back cover from the device.
    • Gently pry open each side of the device at the indicated locations. It is best to use a plastic opening tool or similar tool.
    FixBotに聞いてみる
    コメントを追加
  2. Nokia XL Dual Sim Front Camera Replacement, Battery Removal: 手順 2、 2の画像 1 Nokia XL Dual Sim Front Camera Replacement, Battery Removal: 手順 2、 2の画像 2
    • Remove the back cover.
    • Use a plastic opening tool to lift the battery. Then, remove it.
    FixBotに聞いてみる
    コメントを追加
  3. Nokia XL Dual Sim Front Camera Replacement, Screen Separation part 1: 手順 3、 2の画像 1 Nokia XL Dual Sim Front Camera Replacement, Screen Separation part 1: 手順 3、 2の画像 2
    • To access the inner components of the device, remove the various screws. Keep them separate, and organize them by size.
    • You will need a T5 Precision Torx screw driver to remove the screws.
    • The locations of the T5x3.4mm screws are indicated in the picture.
    • The locations of the T5x4.1mm screws are indicated in the picture.
    FixBotに聞いてみる
    コメントを追加
  4. Nokia XL Dual Sim Front Camera Replacement, Screen Separation part 2: 手順 4、 3の画像 1 Nokia XL Dual Sim Front Camera Replacement, Screen Separation part 2: 手順 4、 3の画像 2 Nokia XL Dual Sim Front Camera Replacement, Screen Separation part 2: 手順 4、 3の画像 3
    • Use the plastic opening tool to gently pry the device apart.
    • There are flaps on both sides of the phone as indicated in the picture. This is what you will need to pry apart.
    • Please be cautious when opening the device. There are various connectors inside the device that must be handled with care.
    FixBotに聞いてみる
    コメントを追加
  5. Nokia XL Dual Sim Front Camera Replacement, System components: 手順 5、 1の画像 1
    • Once the device is open, take note of all the components.
    FixBotに聞いてみる
    コメントを追加
  6. Nokia XL Dual Sim Front Camera Replacement, Camera Removal: 手順 6、 3の画像 1 Nokia XL Dual Sim Front Camera Replacement, Camera Removal: 手順 6、 3の画像 2 Nokia XL Dual Sim Front Camera Replacement, Camera Removal: 手順 6、 3の画像 3
    この手順で使用する道具:
    • With Tweezers, gently unsnap the front camera motherboard connector.
    • The front camera component can now be gently removed.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
6 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Shadeed Bilal
メンバー登録日: 09/25/14
231 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 1-4, Brown Fall 2014 USF Tampa, Team 1-4, Brown Fall 2014人のメンバー
USFT-BROWN-F14S1G4
3 メンバー
21のガイドは作成済み
1件のガイドコメント
merci 1000 fois pour ce cite
zmohye - 返信 共有
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 18
今までの合計 1,442
