必要な工具と部品
The first step is to remove the back cover off of the phone. To do this, place both your thumbs on the two top corners of the device and simply pop it off.
Remove the four 5.33mm T5 Torx screws which are located in the corners of the phone.
Remove the seven 4.00mm T5 Torx screws that line the phone between the corners.
Use a spudger to disconnect the rear-facing camera ribbon cable connector from the motherboard.
Remove the camera module by merely picking it up out of its housing slot.
5 の人々がこのガイドを完成させました。
