メインコンテンツにスキップ
Nokia G310 5G Back Cover Replacement
必要な工具と部品
  1. Nokia G310 5G Back Cover Replacement, Eject the SIM card tray: 手順 1、 3の画像 1 Nokia G310 5G Back Cover Replacement, Eject the SIM card tray: 手順 1、 3の画像 2 Nokia G310 5G Back Cover Replacement, Eject the SIM card tray: 手順 1、 3の画像 3
    • Power down your phone and unplug any cables.
    • Insert a SIM eject tool, bit, or a straightened paper clip into the small hole on the SIM card tray on the upper left edge of the phone.
    • Press firmly to eject the tray.
  2. Nokia G310 5G Back Cover Replacement, Remove the SIM card tray: 手順 2、 3の画像 1 Nokia G310 5G Back Cover Replacement, Remove the SIM card tray: 手順 2、 3の画像 2 Nokia G310 5G Back Cover Replacement, Remove the SIM card tray: 手順 2、 3の画像 3
    • Remove the SIM card tray.
    • When installing either a SIM card or a microSD card, make sure they're in the correct orientation and sitting completely flush with the edges of the tray before reinserting the tray into the phone.
  3. Nokia G310 5G Back Cover Replacement, Insert an opening pick: 手順 3、 3の画像 1 Nokia G310 5G Back Cover Replacement, Insert an opening pick: 手順 3、 3の画像 2 Nokia G310 5G Back Cover Replacement, Insert an opening pick: 手順 3、 3の画像 3
    • The back cover is held in place by plastic clips.
    • Insert an opening pick under the small notch in the SIM card tray slot.
  4. Nokia G310 5G Back Cover Replacement, Release the plastic clips: 手順 4、 3の画像 1 Nokia G310 5G Back Cover Replacement, Release the plastic clips: 手順 4、 3の画像 2 Nokia G310 5G Back Cover Replacement, Release the plastic clips: 手順 4、 3の画像 3
    • Position the opening pick at a steep downward angle between the back cover and the screen assembly.
    • Slide the opening pick down the left edge of the phone to release the plastic clips.
  5. Nokia G310 5G Back Cover Replacement: 手順 5、 3の画像 1 Nokia G310 5G Back Cover Replacement: 手順 5、 3の画像 2 Nokia G310 5G Back Cover Replacement: 手順 5、 3の画像 3
    • Turn the opening pick around the corner and continue to slide it along the bottom edge to release the plastic clips.
  6. Nokia G310 5G Back Cover Replacement: 手順 6、 3の画像 1 Nokia G310 5G Back Cover Replacement: 手順 6、 3の画像 2 Nokia G310 5G Back Cover Replacement: 手順 6、 3の画像 3
    • Slide the opening pick up the right edge to continue releasing the plastic clips.
  7. Nokia G310 5G Back Cover Replacement: 手順 7、 3の画像 1 Nokia G310 5G Back Cover Replacement: 手順 7、 3の画像 2 Nokia G310 5G Back Cover Replacement: 手順 7、 3の画像 3
    • Slide the opening pick along the top edge to release the remaining plastic clips.
    • Don't try to fully remove the back cover just yet, as it's still connected with a cable.
  8. Nokia G310 5G Back Cover Replacement, Flip open the back cover: 手順 8、 3の画像 1 Nokia G310 5G Back Cover Replacement, Flip open the back cover: 手順 8、 3の画像 2 Nokia G310 5G Back Cover Replacement, Flip open the back cover: 手順 8、 3の画像 3
    • With the phone laying screen-side down, carefully lift the right edge of the back cover, opening it like a book.
    • Take care not to strain or tear the attached fingerprint reader cable during this procedure.
    • Lay the back cover next to the phone.
  9. Nokia G310 5G Back Cover Replacement, Unfasten the fingerprint reader bracket: 手順 9、 1の画像 1
    • Use a Phillips screwdriver to remove the 3.8 mm‑long screw securing the fingerprint reader bracket.
  10. Nokia G310 5G Back Cover Replacement, Remove the fingerprint reader bracket: 手順 10、 3の画像 1 Nokia G310 5G Back Cover Replacement, Remove the fingerprint reader bracket: 手順 10、 3の画像 2 Nokia G310 5G Back Cover Replacement, Remove the fingerprint reader bracket: 手順 10、 3の画像 3
    この手順で使用する道具:
    購入する
    • Use a pair of tweezers or your fingers to remove the fingerprint reader bracket.
    • Take care not to puncture the battery with sharp tools—a punctured or creased battery may leak dangerous chemicals or cause a fire.
    • During reassembly, make sure to slide the bracket's edge back into its slot under the motherboard cover.
  11. Nokia G310 5G Back Cover Replacement, Disconnect the fingerprint reader: 手順 11、 3の画像 1 Nokia G310 5G Back Cover Replacement, Disconnect the fingerprint reader: 手順 11、 3の画像 2 Nokia G310 5G Back Cover Replacement, Disconnect the fingerprint reader: 手順 11、 3の画像 3
    • Use the pointed end of a spudger to disconnect the fingerprint reader by prying the connector straight up from its socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
    • Remove the back cover.
  12. Nokia G310 5G Back Cover Replacement, Release the fingerprint reader: 手順 12、 3の画像 1 Nokia G310 5G Back Cover Replacement, Release the fingerprint reader: 手順 12、 3の画像 2 Nokia G310 5G Back Cover Replacement, Release the fingerprint reader: 手順 12、 3の画像 3
    • Using a pair of tweezers, grip the top of the fingerprint reader and lift it out and around the top plastic tab, separating it from the back cover.
  13. Nokia G310 5G Back Cover Replacement, Remove the fingerprint reader: 手順 13、 3の画像 1 Nokia G310 5G Back Cover Replacement, Remove the fingerprint reader: 手順 13、 3の画像 2 Nokia G310 5G Back Cover Replacement, Remove the fingerprint reader: 手順 13、 3の画像 3
    • Use a pair of tweezers to lift the fingerprint reader out of its bottom plastic tab.
    • Remove the fingerprint reader.
    • During reassembly, you'll need to transfer the fingerprint reader to the new back cover.
  14. Nokia G310 5G Back Cover Replacement, Only the back cover remains: 手順 14、 1の画像 1
    • Only the back cover remains.
終わりに
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Manuel Haeussermann
メンバー登録日: 07/13/22
15,619 ポイント
71のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
136 メンバー
17,430のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 11
過去 30 日: 48
今までの合計 441
