メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Nintendo Wii Remote Main Buttons Replacement
必要な工具と部品
  1. Nintendo Wii Remote Main Buttons Replacement, Front Cover Plate and Batteries: 手順 1、 2の画像 1 Nintendo Wii Remote Main Buttons Replacement, Front Cover Plate and Batteries: 手順 1、 2の画像 2
    • Flip the Wii Remote over so the battery cover faces you.
    • Push up on the bottom tab.
    • Remove the battery cover.
    FixBotに聞いてみる
    コメントを追加
  2. Nintendo Wii Remote Main Buttons Replacement: 手順 2、 1の画像 1
    • Remove the first battery by pressing down on the positive end and pulling the battery out.
    • Remove the second battery by pushing up on the positive end and pulling the battery out.
    FixBotに聞いてみる
    コメントを追加
  3. Nintendo Wii Remote Main Buttons Replacement: 手順 3、 1の画像 1
    • Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
    • Repeat with the two bottom screws.
    FixBotに聞いてみる
    コメントを追加
  4. Nintendo Wii Remote Main Buttons Replacement: 手順 4、 2の画像 1 Nintendo Wii Remote Main Buttons Replacement: 手順 4、 2の画像 2
    • With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
    • These tabs are breakable. However, if the tabs are broken the controller will still function.
    • Open the front plate like a book.
    • Small parts may fall out as you open the front plate.
    FixBotに聞いてみる
    コメントを追加
  5. Nintendo Wii Remote Main Buttons Replacement, Main Buttons: 手順 5、 2の画像 1 Nintendo Wii Remote Main Buttons Replacement, Main Buttons: 手順 5、 2の画像 2
    • Working on the inside of the front cover, peel off the three rubber pads covering the buttons.
    FixBotに聞いてみる
    コメントを追加
  6. Nintendo Wii Remote Main Buttons Replacement: 手順 6、 1の画像 1
    • Flip over the cover, allowing the buttons to fall into your hand.
    • Be ready to catch all the buttons, some are very small. If a button does not fall out apply gentle pressure from behind.
    • When reassembling, put each plastic button in its allocated slot. Each button only fits snugly in one slot.
    • The best option for you is rotate the Wii Controller by 180°. If you obey this note, the small parts wont fall off and then you can remove the buttons.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
27 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Emily
メンバー登録日: 04/14/13
2,015 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 3-44, Amido Spring 2013 Cal Poly, Team 3-44, Amido Spring 2013人のメンバー
CPSU-AMIDO-S13S3G44
4 メンバー
29のガイドは作成済み
5件のガイドコメント
Where did you get your replacement buttons? I can't find them online anywhere...
devannedloss - 返信 共有
Me too, can’t find them.
Michael Velten - 返信 共有
2024 and can't find them online ANYWHERE! I'm hoping a WiiUDpad fits on the wiimote. You'd think there'd be a bunch of wiimote shells of different colours available everywhere online, but they're nowhere to be found
how frustrating!
MartianIsotopes - 返信 共有
Vinted is full of them. Although some people ask wayyy too much for them!
Sophie Nicholson - 返信 共有
Yo tampoco los encuentro por ninguna parte
kinoto taller - 返信 共有
コメントを追加
統計データ:
過去 24時間: 14
過去 7 日: 84
過去 30 日: 346
今までの合計 49,457
