メインコンテンツにスキップ
Nintendo Wii の基板の交換
必要な工具と部品
  1. Nintendo Wii の基板の交換, フェイスプレート: 手順 1、 2の画像 1 Nintendo Wii の基板の交換, フェイスプレート: 手順 1、 2の画像 2
    • メタル製のスパッジャーを使用して、Wiiのフロント下部のケースに留められた白色のプラスチックカバーを外します。
    Die Abdeckungen sind geklebt, stecken also nicht.
    Ludger - 返信
    Don’t mistakenly remove the rubber case feet
    Bob Trout - 返信
    I just did. That picture could be better.
    B G -
    Thanks I almost removed the rubber feet
    Lushane - 返信
    If you’re wondering what to use for this, the main blade of a pocket knife from the corner of the plastic works well.
    Cameron Holman - 返信
    As you remove the hardware in each step, place them together on a sheet of paper and circle them with the step number.
    Tom J - 返信
    Very helpful suggestion, thanks!
    Christopher Reese -
    Caution: Before you begin disassembly. If possible, power on your Wii, and attempt to eject whatever disk you may have in the drive.
    Steve - 返信
    1:
    I'd recommend removing the RTC Battery before starting to completely remove all power. You can see how in step 15.
    2:
    When removing the screw covers I'd recommend inserting tweezers in the bottom corners facing away from the rubber feet.
    When the tweezers are inserted you should push them down to grab on to the cover and pull it off.
    Macro Man - 返信
  2. Nintendo Wii の基板の交換: 手順 2、 1の画像 1
    • 取り外したケースの下に隠れている、8.3 mm トライポイントネジを2本外します。
    Before you start, get a small plastic tray with at least 15 small bins in it, and put the screws you take out in each step in the bins in order. It makes reassembly a LOT easier.
    larry - 返信
    NOTE: You need a Y1 screwdriver. Be careful when buying the little red screwdrivers on Amazon that claim to fit the Wii - they don’t!! From personal experience.
    Robotai - 返信
    I have an ifixit kit and the Y1 didn't fit. I ended up using a Y0 and it worked.
    Macro Man -
    Just to add to Robotai’s comment, if you do get the little red/orange screwdrivers on Amazon, file off the tip. It if’s mostly blunt, it fits the tri-wing screws much better.
    jeff - 返信
    1/16 x 1 craftsman Phillips mini screwdriver works for this if you don’t have the tri-wing driver
    grace nicosin - 返信
    How do you make one ? If you don’t have the screwdriver
    Ethan - 返信
    I am using a 18ct empty egg carton to hold the screws/parts removed in the steps.
    karenmparamore - 返信
    Larry’s idea about the bins was great and helpful.
    Robots is right- you NEED a Y1. Just buy the thing with the drive. I didn’t, tried many other options, none worked. Had to order the thing separately with shipping. Mistake….
    David Ryan - 返信
    My two screws hidden are on the backend of the Wii. This picture shows them on the front.
    Leah Wendleton - 返信
    I had to hold the tri point driver in a vice-grip to get the leverage to get these screws out
    Bob Schwarz - 返信
    These screws were really tough for me too. Amazon screw driver was stripping them. I attached a 7 mm socket to the end of the screwdriver and got enough force to get them out.
    NateB - 返信
  3. Nintendo Wii の基板の交換: 手順 3、 1の画像 1
    • フェイスプレート付近のコントローラーポートドア下に付けられた5.9 mm プラスネジを1本外します。
    Pry the square rubber piece in the middle, not the hard plastic square frame.
    David Will - 返信
  4. Nintendo Wii の基板の交換: 手順 4、 1の画像 1
    • メタル製スパッジャーを使って、DVDドライブ挿入口付近の下側にあるゴム足を外します。
    All of the rubber feet on my very old Wii had literally melted into a gooey mess and just needed to be scraper off and cleaned with alcohol.
    Bob Robins - 返信
  5. Nintendo Wii の基板の交換: 手順 5、 1の画像 1
    • 今取り出したゴム足の下に隠れた、5.9 mmプラスネジを1本外します。
    please help! my lil sis got a disc stuck in my wii while it was off!!! please help fast!!!
    Leah Vegan - 返信
    It won’t come out, it will turn and go up but it won’t go fully out
    Mmbb - 返信
  6. Nintendo Wii の基板の交換: 手順 6、 2の画像 1 Nintendo Wii の基板の交換: 手順 6、 2の画像 2
    この手順で使用する道具:
    • Wiiの正面からフェイスプレートを丁寧に引き離します。
    • ピンセットを使ってLEDケーブルのプラスチックコネクターを基板から外します。
    • フェイスプレートを取り外します。
    surprisingly, this was the trickiest step for me. I almost completely mangled the wires when my tweezers slipped as I was attempting to remove the connector.
    rbelknap - 返信
    I removed it with a spudger, gently lift from each side until it pops out.
    For those reassembling
    line up the pins push it in with your spudger gently until it's in. Then line up the front plate, push gently, confirm everything is where it should be and push firmly, I found it needed a strong push to sit flush with the other body panels.
    James middleton -
    I ended up using needle nose pliars on this step.
    Awesome detailed guide made this very easy, thank you author!
    Glenn Woodard - 返信
    Can someone direct me to what I need to do? My tweezers slipped and I cut one of the wires on the connector. Where can I find a new Y plug for the wii?
    jaredslaweski - 返信
    I also broke my wire trying to use tweezers. I should have known better. I use (normally do) a spudger on one side and my fingernail on the other to gently pry these types of connectors out. I ended up buying a replacement faceplate on ebay.
    Tyler - 返信
    This was the hardest part for me. I tried using my fingernails, two different tweezers, and needle nose pliers, but I ended up cutting both the wires. Anyway, I put some electric tape over the exposed wires and just reassembled the system. Funny thing is that the LED still works and I have not noticed any difference. I'm not sure what those wires did, but they seem to not be important.
    Nick - 返信
    For people still wondering after all these years, :), The connector is for the blue leds around the dvd when loading and unloading a disk.
    Niels -
    I also broke off the flimsy wires at the connector. To NOT break the wires, alternate pressing on the right and left sides of the connector with a small flathead screwdriver. Be patient, it will eventually work itself free. There isn't enough to grab onto with the tweezers and you'll only succeed in having them slip off, grab the wires, and yank the wires out.
    Good news is that if you do rip out the wires, no worries... I didn't reconnect them and the unit works just fine. I have no idea what those wires are even for. Power LED continues to work no problem.
    jasendorf - 返信
    I used two small flat head screw drivers, one on each side to pry out the connector. This created less pressure from me and reduced my chance of cutting the wires.
    mulkey - 返信
    This guide is really marvellous - works a treat. But I would definitely recommend needle nose pliers for this step rather than tweezers. It's really easy if you use pliers and potentially damaging if not, and you get it wrong. I had one sniff at it with tweezers then immediate nipped out to the garage for my pliers!
    thepitcanary - 返信
    Definitely a tricky step with that connector. I also cut broke the wire accidentally and was going to just give up trying to fix the Wii. However, as others stated the Wii works just fine, including the lights. I do wonder what those wire are for.
    darcaesar - 返信
    I also had a lot of trouble trying to get the connector off with tweezers. Ended up leaving it attached. It does not really get in the way of remaining steps.
    Ron Even - 返信
    Needlenose pliers did the trick for us!
    Ron Cormier - 返信
    Needlenose pliers did it for us!
    Ron Cormier - 返信
    You can save yourself some trouble at this point and skip the rest of the disassembly: See that green tab to the left of the sd card slot? THAT’S the wifi board (and that green tab, in hindsight, seems designed to make it accessible without taking apart the whole device, don’t you think?) A little careful spudging, and you’ve got it out, ready to replace! (There’s a guy who shows the process on youtube, if you want to review first)
    Will - 返信
    I got the connector out ok thanks to the suggestions here, but I couldn’t figure out how to reattach it. In the end, I just kind of threw it in and it worked fine.
    Christine Wittmer - 返信
    Very clear instructions - thanks! Faceplate needed replacing after one of my son’s friends accidentally kicked it across the room. $10 bucks to fix, thanks to ebay and these instructions. I’d never heard of a “tri-wing” screw before.
    LInda Rawlins - 返信
    I just left the connector alone and kept it connected while working on it. There is enough wire to allow you to do what you need if you are just careful not to snag it on anything.
    Michael Payne - 返信
    I, too, left the connector attached and just took care that the loose faceplate did not stretch the (not crucial) wire when moving rest of the Wii.
    Matti Haveri -
    This was the trickiest part, I almost broke the wires using tweezers and pliers, so instead use a flat end screwdriver to pry it out, when putting it back in use needlenose pliers to start it then use your fingernail to go the rest of the way.
    grace nicosin - 返信
    After I got the connector out I noticed the little locking flap on the top side of the connector. I think prying this first is the key to easier removal.
    Will B - 返信
    Anyone know of a method to replace the connector if you end up breaking the wires? Bits of wire are stuck in the white plastic connector, so I'm wondering if I can buy a connector online somewhere without replacing the whole face plate. Thanks :)
    Bronze Owl - 返信
    I severed both wires. If you want to avoid removing the connector, you can lengthen the two wires by unserpentining them from the wire holder that's in the cover.
    Griff Derryberry - 返信
    Make sure there is no SD card in your unit before pulling this off, otherwise it'll get stuck and you could snap your sd card in half!
    carlosahiciano - 返信
  7. Nintendo Wii の基板の交換, 外付けケース: 手順 7、 3の画像 1 Nintendo Wii の基板の交換, 外付けケース: 手順 7、 3の画像 2 Nintendo Wii の基板の交換, 外付けケース: 手順 7、 3の画像 3
    • コントローラーのポートカバーが黒色コントローラーのポートベゼルに対して垂直になるように開きます。
    • コントローラーのポートカバーを外付けケースから外すため、真っ直ぐ引き上げます。
    • この手順をメモリーカードのポートカバーにおいても繰り返します。
    I wasn't able to reassemble the socket covers when I reversed this step..
    While disassembling, I did as instructed pulling the covers upwards when they where perpendicular to the black cover plate but Nintendos instructions says to open the covers (so that they are perpendicular to the black cover plate) and then gently push the covers towards the console with your fingers on the outside of the cover opposite side of the hinges so that the cover hinges will pop out and then lift it up..
    I'm not sure, but I think ignoring Nintendos instructions caused the hinge sockets to break for me, so replacing the controller/memory card socket covers will not work.
    When reassembling, the cover can be placed perpendicular to the black cover plate and rest on the plastic hinge with a few millimeters between the cover and the console, and then they can be pushed down to click in place. But in my case they keep falling all the way down since there's no resistance and nothing to click into.
    Martin Johansson - 返信
  8. Nintendo Wii の基板の交換: 手順 8、 2の画像 1 Nintendo Wii の基板の交換: 手順 8、 2の画像 2
    • 黒色プラスチック製コントローラーのポートベゼルの上部端に沿って留められた、4.1 mm プラスネジを2本外します。
    • ベゼルをコントローラーポートから反対側の長い先端から持ち上げます。そしてベゼルをWiiから取り外します。
    The 3rd hole is in step 3.
    James middleton - 返信
    The bezel is the flat black plate. Removing the three screws that secure it allows you to remove it. If your cube is like mine, this plate likes where it lives and, even with the screws removed, managed to stay in situ without anything holding it.
    Dennis Johnston - 返信
    Beware. The edge of the bezel, opposite these screws, has clips. Lift the bezel from the top edge, where the the screws are, to avoid breaking these clips.
  9. Nintendo Wii の基板の交換: 手順 9、 1の画像 1
    • コントローラーポートの上に留められた5 mm プラスネジを2本、外します。
  10. Nintendo Wii の基板の交換: 手順 10、 1の画像 1
    • メタル製のスパッジャーを使って、Wiiサイドに留められた3箇所のネジカバー(赤くハイライトしています)を外します。
  11. Nintendo Wii の基板の交換: 手順 11、 1の画像 1
    • 次のネジを外します。
    • 5 mmプラスネジー2本
    • 8.2 mmトライポイントネジー1本
    Instead of the Phillips screw on the left I had a very small one under a cover to the left of that!
    Donna Vought - 返信
  12. Nintendo Wii の基板の交換: 手順 12、 1の画像 1
    • メタル製のスパッジャーを使って、リアポート付近のWii底面に留められた2箇所のゴム足を外します。
  13. Nintendo Wii の基板の交換: 手順 13、 1の画像 1
    • 先ほど取り出したゴム足の下に隠れている8.2 mmトライポイントネジを2本外します。
    • 4mmの六角ドライバーを使えば、ビットを凹みまで伸ばし、ネジに届くことができます。
    had a little trouble with theses screws. they were just barely too deep for my 54pies bit driver kit to reach. I ended up inserting a small wad of paper into the shaft of my driver so the tri-wing bit stuck out far enough to engage the screw. (I used the tweezers to remove the paper when I was done) :)
    rbelknap - 返信
    I can confirm, this works fantasticly!
    Thank you
    James middleton -
    When putting the screws back in hold the tip still with the screw and carefully drop it in.
    James middleton -
    When i tried it didn't work. But i did get it to work with blu tack instead as it holds better. It was alot harder to remove though.
    Macro Man -
    Thank you rbelknap, this is excellent advice for those using the ifixit branded driver.
    George Squires - 返信
    You could also use the 4mm nut driver in the iFixit kit to turn the tri-wing driver. This will give you a little more reach.
    Edward Tucker - 返信
    How is no one talking about the included 4mm nut driver trick at Edward Tucker mentioned?! That is genius! Thanks mate!
    Zabuza -
    That's the idea that I needed. Agree with Zabuza.
    cwdick -
    Bingo. All of the other comments were unnecessary.
    Tony Shannon -
    Because it doesn't come with the screw driver in the kit. Only has the tri wing and the cross tips.
    Craig Goodsell -
    This paper wad trick totally worked for me too!
    anonymous 779 - 返信
    Standard Tri-Wing bits will NOT fit into the holes. Make sure that you get one of the tool kits from iFixit (I just ordered the Mako Driver/Bit kit with 64 bits ) - the Tri-Wing bits in this kit have a narrow shaft that allows it to reach deep into narrow holes like these on the Wii . (Disclaimer - I have no association with iFixit).
    dave whale - 返信
    I just sawed off a bit of the shank holder from the iFixit tool, in order for the bit to go deep enough into the case.
    The tool still works fine.
    Alan Walker - 返信
    Thanks for the paper wad trick advice! Worked perfectly with my Wii
    Finder352 - 返信
    The 4mm driver was the exact fix for this problem, no mods necessary
    Tony Shannon - 返信
    I just realized that my ifixit kit never came with the 4mm driver! Instead they sent me two 3.5mm ones.
    gawift - 返信
    put a little gorilla tap around the shaft of the driver, that was the trick for me to get it to reach down
    SmokeyBare - 返信
  14. Nintendo Wii の基板の交換: 手順 14、 1の画像 1
    • Wii本体から外付けケースを真っ直ぐ持ち上げて外します。
    This step could use at least another picture from the backside so it's clearer what comes up and what stays down.
    Jose Vazquez - 返信
    I used a spudger around the edges of the outer case to gently ease it upward since I could not lift it out with my fingers. Then it came right out.
    Marko - 返信
    Good tip. Having, in the past, broken pieces that required a little persuasion, I attempted to "lift" the outer case, but it wouldn't budge. Using the spudger to persuade it worked like a charm. Also added this suggestion to Step 18 "Lift the drive shield."
    Dennis Johnston -
    hey marko that really helped me thanks\. als if you need help figuring which side is up, its the one with the nintendo engraving on it
    Aryan Garg - 返信
    A fan filter fell out at this step how do you put it back?
    Edit: I figured it out it was from the side intake vent. Just line up the two notches with the pegs in the case to hold it in place
    Darren Jones - 返信
    This is an awful guide
    Alexander D Schaefer - 返信
    Yeah. I don't know why most of the official ifixit guides suck.
    Macro Man -
  15. Nintendo Wii の基板の交換, DVDドライブ: 手順 15、 2の画像 1 Nintendo Wii の基板の交換, DVDドライブ: 手順 15、 2の画像 2
    • 底面に留められたバッテリードアから小サイズのプラスネジを1本外します。
    • このネジはバッテリードアに付けられています。
    • Wiiからバッテリードアを引っ張り外します。
    • バッテリードアを外すと、システム時刻はリセットされます。
    • 最近バッテリーを交換していない場合は、 CR2032 バッテリーを交換できるよい機会です。
    The screw on the battery door of my Wii required a Phillips #000 screwdriver, which is not listed in the required tools.
    Ben - 返信
    The screw is a PH0000 (quadruple zero) requiring an exceptionally small Phillips screwdriver to remove. If this is your first time in here in a while, this may also be a great time to change the CR2032 battery.
    Steve Bonds - 返信
    I was able to use the ph0 no problem.
    Darren Jones -
    I used a 00 with no problem.
    julie -
    What does this battery do? I never knew there was a battery inside of the WIi.
    Stephen Thornhill - 返信
    thje battery is used to maintain timwe and date etc
    Electronik -
    Where can we get a new battery from?
    Chriul Rg - 返信
    You can get a CR2032 batterie in your local supermarkt. It is recommended to change it after 5 years, but I have seen devices run for 15+ years.
    Playa -
    my wii survived 15 years already with the same battery
    Bas Molendijk - 返信
    I tried using a PH000, PH00, and PH0 screwdriver to no avail. I tried searching online for a PH0000 bit or screwdriver, and can't find anything. How can I unscrew this without stripping the screw or buying a PH0000 bit/screwdriver?
    Keiran Haas - 返信
    0000 bits are hard to come by, but you shouldn't need one. Is yours stuck on? Is it stripped at all?
    Isak -
  16. Nintendo Wii の基板の交換: 手順 16、 1の画像 1
    • バッテリードアの下に隠れている 8.2 mmトライポイントネジを外します。
    Note - this screw is a machine screw (e.g. not self-tapping). It screws into a hex nut, and that nut is captive in a slot in the case. When reassembling, ensure that this hex nut is still captive, and has not migrated out to other areas within the Wii.
    dyanetti - 返信
    The other drive cage hole is screwed in step 11, continue to reassemble.
  17. Nintendo Wii の基板の交換: 手順 17、 1の画像 1
    • コントローラーのポート付近のDVDシールドに留められた 8.2 mmトライポイントネジを2本外します。
    The screw on the right for my wii just refuses to come out
    Robert Menocal - 返信
    I put my 3point driver in a vise grip to get the leverage on the screws
    Bob Schwarz - 返信
    Bob Schwarz - 返信
  18. Nintendo Wii の基板の交換: 手順 18、 1の画像 1
    • WiiからDVDドライブシールドを上向きに持ち上げて外します。
    Be careful not to cut your fingers on the sharp edges of this metal shield. My daughter actually scraped enough skin to cause blood to drip off her finger. Then we noticed her skin stuck to the metal edge. Yuk.
    J Smith - 返信
    True story I did it to myself lol
    James middleton -
    Does the dvd shield need to be there? I want to remove it but im not sure if i should
    Kadamo - 返信
    If the drive shield needs a little extra persuasion, us a spudger around its perimeter. Also helps prevent cuts when force meets resistance on this metal shield.
    There are spring steel tabs on both sides.
  19. Nintendo Wii の基板の交換: 手順 19、 1の画像 1
    • 底面パネルにDVDドライブを固定している、9 mm #1プラスネジ4本を外します。
    The two left hand screws were very difficult to relocate during reassembly. I was coaching my 8 year old through this, and this was probably the only step that he couldn't do. We dropped these screws several times, and used magnets to retrieve. Miniature needle-nose pliers gripping the 'washer' surface of the screw were too wide. We managed to purchase the 'button head' of these screws with the needle-nose and drop the screws into their hole, and push with the phillips until secure. I would like to hear how others install these screws, please.
    dyanetti - 返信
    I had the same problem as you and eventually found an easy way round it. I wrote this to be added to the instructions but it was rejected: "Once the DVD drive has been removed, remove the 4 rubber washers from the screws removed earlier and insert them into your new DVD drive. Because two of the screws are difficult to reach, it is best to insert these two screws into the washers and then slide them into place ready for securing to the base plate".
    The rubber washer holds the two screws roughly in position, you can then reach them with your screwdriver through the two holes (about an inch away) and finish tightening them up.
    Gary -
    For the two screws at the front of the chassis, use a three-pronged parts retriever to lift them out after you unscrew them.
    Walter - 返信
    Helpful tip: Use a magnetized screwdriver for the 2 screws nearest the DVD face because they are set in deep sockets
    Blake Minghelli - 返信
    During reassembly, it can be tricky to position the recessed screws. To temporarily magnetize your screwdriver, rub the tip against a magnet for 5-10 seconds. (A refrigerator magnet will do.) You should then be able to put the screw on the tip and gently lower it into position.
    Matt D - 返信
    Thanks - the refrigerator magnet trick worked for me,
    Jim Allen -
    Another method for getting the front screws back in is to insert a small pair of tweezers through the DVD slot to guide the screw in. I just dropped the screw in between the tweezers which held the screw just above the hole. Then I was able to use the phillips screwdriver to guide the screw into the hole and screw it in. Done in just a few seconds.
    Another option would be to stick a dab of hot glue on the screw to your screwdriver and then when the screw has been driven home either the glue stays on the driver and is easily removed or it stays on the screw and you just pull it off with tweezers or needle nose pliers.
    accts4mjs - 返信
    The screwdriver provided in the kit by ifixit is a magnetized screwdriver and works perfectly!
    mulkey - 返信
    If you are disassembling your Wii because, say, a two-year-old has shovelled pennies into it (yes, that was me) you will also need to partially disassemble the drive itself, which is not covered in this guide. Luckily it's really easy. Unscrew the 4-5 larger Philips/cross head screws on the top of the frame (NOT any of the smaller darker ones) around the edges, and the frame on top of the drive will lift right off. Be careful as there is cabling running to it, so don't yank it or pull it too far off. You will now be able to get any coins or other foreign objects out.
    thepitcanary - 返信
    I didn't have a magnetic screwdriver, so I applied a tiny amount of fabric glue to the head of each screw, waited a minute for it to start to harden, inserted my non-mag screwdriver into the screw head, and the screw stuck to the screwdriver long enough to insert it into the hole.
    Lee Crooks - 返信
    Be advised that the posts that these screws go into are very fragile and may even break. Make sure to get the little plastic pieces out if you over tighten them or they are just brittle and broken to begin with. The screws seem to be long enough to work if you do break the posts off completely.
    Michael Payne - 返信
    I needed a size 1 Phillips screwdriver for this step.
    julie - 返信
    Thanks, I will include it in the guide
    Angel -
    Be careful with these screws - they seem to be quite malleable and easy to strip.
    Electronik - 返信
    I ended up using an extra fine tweezers from a watch kit, stuck it through the vent opening "inside" the screw area and acted as guideposts to thread in. Only because I didn't have a magnet for the screw.
    kwjayhawk - 返信
    I guess this is a warning applicable to anything that has to do with plastics, but this step in particular: Be extra careful not to overtighten these screws when reassembling the unit because the plastic sockets will easily break/shatter..
  20. Nintendo Wii の基板の交換: 手順 20、 1の画像 1
    • 底面のケーブルにアクセスできるように、コントローラーポート反対側のDVDドライブのサイドを持ち上げます。
    • 丁寧にDVDドライブパワーのケーブルをヒートシンク付近のプラスチック製シュラウドから引っ張り外します。
    When reversing these steps to reassemble the Wii, at this point it is possible to do a quick test before screwing the drive to the case. This will save you a lot of time if something is wrong.
    Don't touch anything you don't have to while the case is off.
    Carefully plug the power cable into the back of the Wii, then use a screwdriver to gently press the white button next to the glowing yellow LED on the front. You should hear the DVD drive power up and whir. Then press the white button again, wait for the yellow light to come back, and unplug the Wii.
    If you didn't hear the drive start up, most likely one of the two ribbons isn't connected to the drive correctly. Doublecheck the previous 3 steps.
    Matt D - 返信
  21. Nintendo Wii の基板の交換: 手順 21、 1の画像 1
    • DVDドライブのパワーケーブルをDVDドライブのソケットから接続を外します。
    When reversing this step, be careful re-inserting the connector. The pins are very delicate and if you aren't at the proper angle, you can bend them and ruin the drive.
    jisakoff42 - 返信
    The exact thing happened to me just now; I reinserted it at a (very slight) angle, and bent one of the pins at the end of the socket. Luckily, I was able to straighten it back up with a sewing needle. I made sure the spacing was consistent with the rest of the pins, and that I reinserted the connector as straight as I could, so it doesn’t happen again.
    Jose Olarte III -
    Reinsterting the connection caused the connecter to fall of the print borad, even if I was very careful.
    On the orginal board, the connector is solid as a rock.
    Bjørn Johannesen - 返信
    1) The silver cable doesn’t need any force to insert - just push it gently in and use the retaining flap to lock it in place;
    2) The DVD drive power cable is a little tricky because of the orientation - take a look of the pins inside the socket: it is located more toward the outside surface (not in the middle). As such, check your cable orientation before insert, make sure it is in the right orientation such that the holes will meet the pins. It takes me one try to snug it in nicely.
    David Will - 返信
  22. Nintendo Wii の基板の交換: 手順 22、 2の画像 1 Nintendo Wii の基板の交換: 手順 22、 2の画像 2
    • 指の爪を使って、DVDドライブのリボンケーブルソケットから固定フラップを裏返しにして持ち上げます。
    • 固定フラップのみ持ち上げて、ソケット自体には接触しないでください。
    • ソケットからDVDドライブのリボンケーブルの接続を外します。
    • WiiからDVDドライブを取り出します。
    When reversing this step, make sure the ribbon is all the way in. For some reason I found positioning it with my replacement drive was much harder than with my old drive. The gentlest tug after lowering the brown clip would show that the ribbon was not actually being held tightly. I thought for a while that the clip itself was broken, but eventually I got it to hold the ribbon correctly.
    Matt D - 返信
    Be careful with this step. I too had difficulty re-inserting the ribbon. I even popped off the brown clip and thought I broke it. Thankfully it snapped back into place.
    Dana Kennard - 返信
    It is difficult to tell, but be aware that the brown piece is the retaining flap, not the light piece , which is the actual socket.
    Dan Neunaber - 返信
    I had to use Kapton tape. I couldn’t get the clip back on.
    Jim Allen - 返信
    This was the trickiest step for me. Take note of how the ribbon is configured before you loosen the clip to help you replace it with confidence in the right way.
    Ping Wu - 返信
    Careful! When reinstalling, I think I bent and broke the ribbon. The Wii doesn't respond upon power up - I think because it doesn't see the drive.
    Steve Bennett - 返信
  23. Nintendo Wii の基板の交換, 基板カバー: 手順 23、 1の画像 1
    • ピンセットを使って、ファンコネクターを持ち上げて、ロジックボードのソケットから接続を外します。
    • ピンセットがファンコネクターをしっかり掴んでいるか確認してください。基板上のソケットは掴まないようご注意ください。
  24. Nintendo Wii の基板の交換: 手順 24、 2の画像 1 Nintendo Wii の基板の交換: 手順 24、 2の画像 2
    • ファンシュラウドに留められたファンから10 mmプラスネジを2本外します。
    • Wiiからファンを取り出します。
    There may be a removable metal "comb" under the fan shroud, remove after removing the fan shroud when disassembling, and replace before inserting the fan shroud when reassembling: it is held in place with same screws as fan shroud.
    Gregory Salton - 返信
  25. Nintendo Wii の基板の交換: 手順 25、 2の画像 1 Nintendo Wii の基板の交換: 手順 25、 2の画像 2
    • スパッジャーの先端や先端が鋭利なツールを使って、Wi-Fiアンテナボードからファンシュラウドに付けられた黒色のプラスチック製固定フィンガーの一つを丁寧に外します。
    • Wi-Fiアンテナをファンシュラウドから持ち上げて外します。
    I messed up the gray wire on the antenna part is it possible to solder it back on or do I have to replace it?
    DreadHeadNon - 返信
  26. Nintendo Wii の基板の交換: 手順 26、 1の画像 1
    • ファンシュラウドの上部で2番目のWi-Fiアンテナに留められた10 mmプラスネジ1本を外します。
  27. Nintendo Wii の基板の交換: 手順 27、 1の画像 1
    • ヒートシンク付近のプラスチック製ブラケットに留められた2番目のWi-Fiアンテナケーブルから2つのテープを剥がします。
    Some newer models may have the Wi-Fi antenna wires taped to the top of the plastic bracket instead of the front as pictured.
    Jabu - 返信
  28. Nintendo Wii の基板の交換: 手順 28、 1の画像 1
    • Wiiのフレームから両方のアンテナを丁寧に巻き戻し、傍に置きます。
  29. Nintendo Wii の基板の交換: 手順 29、 2の画像 1 Nintendo Wii の基板の交換: 手順 29、 2の画像 2
    • Wiiのファンシュラウドに留められた10 mmのプラスネジを3本外します。
    • ヒートシンクからファンシュラウドを持ち上げて、Wiiから取り出します。
    Mine (RVL-CPU-01) Is probably The first revision, and mine had another EMI Shield Under the fan shroud. I’m Guessing that they removed it in later revisions. It just fits under the shroud normally. For Pics, here is a link. Images are there soon.
    https://sites.google.com/site/ninteardow...
    Lucas Hoekstra (Lucas9810) - 返信
    One of these three screws (the one in the 5o'clock position) seems to always be tight and difficult to remove
    Will Moindrot - 返信
  30. Nintendo Wii の基板の交換: 手順 30、 3の画像 1 Nintendo Wii の基板の交換: 手順 30、 3の画像 2 Nintendo Wii の基板の交換: 手順 30、 3の画像 3
    • 底面に留められたEMIフィンガーから次の6本のネジを外します。
    • 7 mmプラスネジー4本
    • 11.3 mmプラスネジー2本
    • WiiからEMIフィンガーの両セットを外します。
    Actually, at east for me, these “fingers” were beneath the motherboard cover, and the screws could be removed at the same time as the ones on step 33.
    shaitanpt - 返信
    shaitanpt thanks for pointing this out! Mine were also beneath the motherboard cover, and the first set of "fingers" were actually two small brackets between the controller ports, rather than one long bracket over all of them.
    Cynthia - 返信
  31. Nintendo Wii の基板の交換: 手順 31、 2の画像 1 Nintendo Wii の基板の交換: 手順 31、 2の画像 2
    • 次の3本のネジを外します。
    • 7 mmプラスネジー1本
    • 10 mmプラスネジー2本
    • Wiiからブラケットを持ち上げて外します。
    Be careful not to drop the 7 mm. I did and I spent 10 minutes trying to roll it and rattle it out from under the shroud, until I figured out that you can just remove the fan and shake it out of the bottom
    Curt Swalley - 返信
  32. Nintendo Wii の基板の交換: 手順 32、 3の画像 1 Nintendo Wii の基板の交換: 手順 32、 3の画像 2 Nintendo Wii の基板の交換: 手順 32、 3の画像 3
    • Wiiの正面付近の底面に付けられた黒色のブラケットから10 mm プラスネジを3本外します。
    • わずかにブラケットを持ち上げて、片手を使ってWi-Fiアンテナが基板シールドに入り込む場所から固定クリップを引っ張ります。
    • Wiiからブラケットを取り出します。
    • 画像にあるように黒色のプラスチック製ブラケットに緩く留められている小サイズの四角ナットを紛失しないようにご注意ください。
    For reassembly: I believe the nut is for the CR2032 battery
    Jack Bailey - 返信
  33. Nintendo Wii の基板の交換: 手順 33、 1の画像 1
    • 底面側の基板カバーから9本の7 mmプラスネジを外します。
    I believe that's 10 screws
    Will Moindrot - 返信
    Before you put this plate back on, you need to put the six metal comb looking thing underneath it
    Logie - 返信
  34. Nintendo Wii の基板の交換: 手順 34、 1の画像 1
    • マザーボードから丁寧に基板カバーを持ち上げてます。絡まないようにケーブルにご注意ください。
    • 一部の機種では、マザーボードカバーの裏側にワイヤレスチップ用のサーマルパッドが取り付けられています。再組立の際には必ず交換してください。
    There is a thermal pad on the WiFi chip as well! NB this because disassembling past this point requires you to also reapply a thermal pad to the WiFi chip.
    Jonatan Noponen - 返信
    When reassembling, put the wifi fingers near the battery compartment beneath the motherboard cover before screwing the cover back on. Can someone add "thermal paste" to the items needed to the top of the guide?
    Gregory Salton - 返信
  35. Nintendo Wii の基板の交換, ヒートシンク: 手順 35、 1の画像 1
    • 底面に留められたヒートシンクから11.3 mmのプラスネジを4本外します。
  36. Nintendo Wii の基板の交換: 手順 36、 1の画像 1
    • 基板からヒートシンクを持ち上げます。
    • プロセッサの近くで作業する際に、サーマルパッドを交換する予定がない場合は、このサーマルパッドを作業中触れないように注意してください。パッドは壊れやすく、簡単に破れることがあります。代わりに交換する予定がある場合は、放熱グリスを使用することができます。
    Would it make sense to use thermal compound instead?
    BRUCEL86 - 返信
    I would recommend to still using thermal pads, because there are big gaps between the heatsink and the chip that thermal paste will not spread and fill the gap.
    CCX Cheng - 返信
    K5-Pro is also a solution I am happy with
    Playa - 返信
    You need to use the pads. I would not recommend paste. The pre-smashed dimensions of the pads are 1.5mm thick and one is 20mmx20mm and the other is 15mmx15mm. (so, two 20x20x1.5's would have you covered easily.) Also missing is the torque on the heatsink. However there was a lot of effort on the pictures and I appreciate that!
    david1024 - 返信
    So what is the torque spec on the heatsink then?
    Alex Dorman -
    THERMAL PASTE??? This will fry your console as the gap between HS and CPU is too big.
    Kolomanšell - 返信
    Bad call on saying thermal paste was acceptable. There's like a 1-2mm gap between the heatsink and GPU/CPU.
    arick - 返信
  37. Nintendo Wii の基板の交換, 基板: 手順 37、 1の画像 1
    • ヒートシンクから最も離れた場所にあるWi-Fiボードの端を持ち上げて、基板のソケットから接続を外します。コネクターの端にプレッシャーが入らないようご注意ください。
    • Wi-FiボードとアンテナをWiiから取り出します。
  38. Nintendo Wii の基板の交換: 手順 38、 1の画像 1
    • スパッジャーの平面側先端か指の先を使って、基板のセンター付近にあるBluetooth ボードの端を持ち上げます。
    • 基板に装着されたEMIフォームからBluetooth ボード正面の端を丁寧にはがします。
    • Bluetooth ボードを取り出します。
  39. Nintendo Wii の基板の交換: 手順 39、 2の画像 1 Nintendo Wii の基板の交換: 手順 39、 2の画像 2
    • 指の爪を使ってDVDドライブリボンケーブルの固定フラップを裏返します。
    • 固定フラップのみ裏返して、ソケット自体には接触しないでください。
    • DVDドライブのリボンケーブルをソケットの接続から外し、Wiiから取り出します。
  40. Nintendo Wii の基板の交換: 手順 40、 1の画像 1
    • 丁寧にDVDドライブのパワーケーブルを基板上のソケットから離して、Wiiから取り出します。
  41. Nintendo Wii の基板の交換: 手順 41、 1の画像 1
    • 丁寧に基板の端を掴んで持ち上げ、底面から離します。
終わりに
デバイスを再組み立てする際は、これらのインストラクションを逆の順番に従って作業を進めてください。
48 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
翻訳を始める ›
作成者
4人の作成者と共同で作成されました。
Andrew Bookholt
592,015 ポイント
619のガイドは作成済み
5 件のコメント
Any idea if there is a common issue effecting these motherboards that causes them to fail? Perhaps I'm wondering if there is a best-practice method for determining where and/or why my Wii's MB failed (circuit tracing, component testing, soldered fuses, etc.). Upon lengthy inspection, I am unable to find any components with the usually noticeable burn marks, leaky/exploded capacitors, discolored parts or similar visual cues telling me why this MB failed.
And as a side note, I've already testing this Wii's power supply and it's 100%.
Thoughts?
Ryan R. Smith - 返信
I just found this post about on-board fuses, but the other parts of my original question still apply.
Nintendo Wii Drive Board Fuse Replacement
If I determine it's a fuse-related issue, I'll post an update here.
Ryan R. Smith - 返信
Our WII unit was hit by a power surge…was not able to get it to work after that. Will motherboard replacement likely resolve most issues related to this?
Brian Walk - 返信
Thank you for these detailed instructions! I was able to replace my original 01 board with rev. 60 and it's working beautifully! Can't thank you enough!
Dan Melton - 返信
Thanks for this guide, the pictures are very helpful! I was able to use this to help replace the original white shell with an after-market one.
Cynthia - 返信
コメントを追加
統計データ:
過去 24時間: 24
過去 7 日: 146
過去 30 日: 632
今までの合計 100,798
