メインコンテンツにスキップ
Nintendo Wii Drive Board Fuse Replacement
必要な工具と部品
  1. Nintendo Wii Drive Board Fuse Replacement, Faceplate: 手順 1、 2の画像 1 Nintendo Wii Drive Board Fuse Replacement, Faceplate: 手順 1、 2の画像 2
    • Use a metal spudger to remove the white plastic screw covers stuck to the lower case near the front of the Wii.
  2. Nintendo Wii Drive Board Fuse Replacement: 手順 2、 1の画像 1
    • Remove the two 8.3 mm Tri-Point screws hidden under the covers you just removed.
  3. Nintendo Wii Drive Board Fuse Replacement: 手順 3、 1の画像 1
    • Remove the single 5.9 mm Phillips screw under the controller port door nearest the faceplate.
  4. Nintendo Wii Drive Board Fuse Replacement: 手順 4、 1の画像 1
    • Use a metal spudger to remove the rubber foot stuck to the side of the Wii near the DVD drive opening.
  5. Nintendo Wii Drive Board Fuse Replacement: 手順 5、 1の画像 1
    • Remove the single 5.9 mm Phillips screw hidden under the foot you just removed.
  6. Nintendo Wii Drive Board Fuse Replacement: 手順 6、 2の画像 1 Nintendo Wii Drive Board Fuse Replacement: 手順 6、 2の画像 2
    • Carefully pull the faceplate away from the front of the Wii.
    • Use a pair of tweezers to disconnect the LED cable's plastic connector from the motherboard.
    • Remove the faceplate.
  7. Nintendo Wii Drive Board Fuse Replacement, Outer Case: 手順 7、 3の画像 1 Nintendo Wii Drive Board Fuse Replacement, Outer Case: 手順 7、 3の画像 2 Nintendo Wii Drive Board Fuse Replacement, Outer Case: 手順 7、 3の画像 3
    • Open the controller port cover until it is perpendicular to the black controller port bezel.
    • Pull the controller port cover straight up to release it from the outer case.
    • Repeat this procedure for the memory card port cover.
  8. Nintendo Wii Drive Board Fuse Replacement: 手順 8、 2の画像 1 Nintendo Wii Drive Board Fuse Replacement: 手順 8、 2の画像 2
    • Remove the two remaining 4.1 mm Phillips screws along the top edge of the black plastic controller port bezel.
    • Lift the bezel from the long edge furthest away from the controller ports and remove it from the Wii.
  9. Nintendo Wii Drive Board Fuse Replacement: 手順 9、 1の画像 1
    • Remove the two 5 mm Phillips screws above the controller ports.
  10. Nintendo Wii Drive Board Fuse Replacement: 手順 10、 1の画像 1
    • Use a metal spudger to remove the three highlighted screw covers stuck to the side of the Wii.
  11. Nintendo Wii Drive Board Fuse Replacement: 手順 11、 1の画像 1
    • Remove the following screws:
    • Two 5 mm Phillips screws
    • One 8.2 mm Tri-Point screw
  12. Nintendo Wii Drive Board Fuse Replacement: 手順 12、 1の画像 1
    • Use a metal spudger to remove the two rubber feet stuck to the bottom face of the Wii near the rear ports.
  13. Nintendo Wii Drive Board Fuse Replacement: 手順 13、 1の画像 1
    • Remove the two 8.2 mm Tri-Point screws hidden under the feet you just removed.
    • You may use a 4 mm hex driver to extend your bit into the recesses and reach the screws.
  14. Nintendo Wii Drive Board Fuse Replacement: 手順 14、 1の画像 1
    • Lift the outer case straight up off the body of the Wii.
  15. Nintendo Wii Drive Board Fuse Replacement, DVD Drive: 手順 15、 2の画像 1 Nintendo Wii Drive Board Fuse Replacement, DVD Drive: 手順 15、 2の画像 2
    • Remove the small Phillips screw securing the battery door to the bottom panel.
    • This screw is captive to the battery door.
    • Pull the battery door out of the Wii.
    • The system time will be reset once you remove the battery door.
    • This is a good time to change the CR2032 battery if it hasn't been changed recently.
  16. Nintendo Wii Drive Board Fuse Replacement: 手順 16、 1の画像 1
    • Remove the 8.2 mm Tri-Point screw that was hidden beneath the battery door.
  17. Nintendo Wii Drive Board Fuse Replacement: 手順 17、 1の画像 1
    • Remove the two 8.2 mm Tri-Point screws securing the DVD drive shield near the controller ports.
  18. Nintendo Wii Drive Board Fuse Replacement: 手順 18、 1の画像 1
    • Lift the DVD drive shield upward and remove it from the Wii.
  19. Nintendo Wii Drive Board Fuse Replacement: 手順 19、 1の画像 1
    • Remove the four 9 mm #1 Phillips screws securing the DVD drive to the bottom panel.
  20. Nintendo Wii Drive Board Fuse Replacement: 手順 20、 1の画像 1
    • Lift the side of the DVD drive opposite the controller ports enough to access the cables on its bottom face.
    • Carefully pull the DVD drive power cable out from under the plastic shroud near the heat sink.
  21. Nintendo Wii Drive Board Fuse Replacement: 手順 21、 1の画像 1
    • Pull the DVD drive power cable away from its socket on the DVD drive.
  22. Nintendo Wii Drive Board Fuse Replacement: 手順 22、 2の画像 1 Nintendo Wii Drive Board Fuse Replacement: 手順 22、 2の画像 2
    • Use your fingernail to flip up the retaining flap on the DVD drive ribbon cable socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the DVD drive ribbon cable out of its socket.
    • Remove the DVD drive from the Wii.
  23. Nintendo Wii Drive Board Fuse Replacement, Drive Board Fuses: 手順 23、 1の画像 1
    • Measure across each fuse with a continuity meter.
    • If either fuse is open, you will need to replace it with an 0603 fuse; if one is not available, you can use a 0-ohm resistor or jumper wire for testing purposes.
終わりに
15 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
bushing
メンバー登録日: 04/23/10
10,247 ポイント
13のガイドは作成済み
4 件のコメント
Soldering jumpers on those fuses is easier said than done. The left-hand fuse follows the same trace all the way to the larger solder pad above, so don't worry about bridging. But it looks like there's a cap or diode along the trace of the right-hand fuse, so solder carefully! This worked great, and got my Wii drive back to spinning without spending $80 on a new drive.
Robert Allshouse - 返信
If anyone could give specifications for the fuses needed, it would be very much appreciated... 0603 Fuses come in different amp ratings. I saw one person suggest elsewhere that after research he found that the ones used in this repair are 2A 0603 fuses, can anyone confirm this please before I get the wrong ones?
Thanks in advance,
James @ Retro Gaming Repair UK
Retro Gaming Repair - 返信
I found a datasheet for littelfuse which labels the fuse as 2A. The datasheet can be found here
http://www.littelfuse.com/data/en/data_s....
Hope this helps.
Another tip for after you know the fuse is blown instead of removing the fuse and jumpering it add a little solder on both sides of the fuse then use a lead from a resister heating up the solder and push the lead from a resistor into it then do the same for the other side.
randyhenke - 返信
this guide assumes you have one revision of the board....i have another revision and can only find one of the resistors
dude105tanki - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 36
過去 30 日: 247
今までの合計 60,737
