メインコンテンツにスキップ
Nintendo Switch Pro Controller Buttons / D-Pad Replacement
必要な工具と部品
  1. Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the screws: 手順 1、 1の画像 1
    • Flip the controller over so the model stickers face the ceiling.
    • Use a JIS #00 screwdriver to remove the two black 8.4 mm screws that secure the handles, located at the ends of the handles.
  2. Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the handle covers: 手順 2、 3の画像 1 Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the handle covers: 手順 2、 3の画像 2 Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the handle covers: 手順 2、 3の画像 3
    • Carefully remove the handle covers by pulling them away from the main body.
  3. Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the screws: 手順 3、 1の画像 1
    • Use a JIS #00 screwdriver to remove the four silver 6.8 mm screws that secure the clear back plastic cover.
  4. Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Unclip the plastic cover: 手順 4、 3の画像 1 Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Unclip the plastic cover: 手順 4、 3の画像 2 Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Unclip the plastic cover: 手順 4、 3の画像 3
    • Carefully pry away the clear plastic cover using your fingernail.
  5. Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the clear plastic cover: 手順 5、 1の画像 1
    • Remove the clear plastic cover.
  6. Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the battery: 手順 6、 3の画像 1 Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the battery: 手順 6、 3の画像 2 Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the battery: 手順 6、 3の画像 3
    • Remove the lithium-ion battery by using a fingernail or plastic opening tool to pry it up on the left side.
    • Only a small amount of force is needed.
  7. Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the screws: 手順 7、 3の画像 1 Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the screws: 手順 7、 3の画像 2 Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the screws: 手順 7、 3の画像 3
    • Use a Phillips #1 screwdriver to remove the five 5 mm screws from the back of the controller.
    • The two case screws above the handgrips and the single case screw below the battery bay have a shallow seat. These three screws can be easily removed.
    • The two case screws adjacent to the ZR and ZL shoulder buttons have a deep seat. Use an extension or a Phillips screwdriver with a longer shaft to reach these screws.
  8. Nintendo Switch Pro Controller Buttons / D-Pad Replacement: 手順 8、 3の画像 1 Nintendo Switch Pro Controller Buttons / D-Pad Replacement: 手順 8、 3の画像 2 Nintendo Switch Pro Controller Buttons / D-Pad Replacement: 手順 8、 3の画像 3
    • There's an adhesive pad located in the center of each handle. It will require a bit of force to pry away the front cover, but be mindful of the attached ribbon cable.
    • Delicately take off the plastic cover from the controller.
    • Don't completely remove the front cover just yet, as it's still attached to the motherboard via a white ribbon cable.
  9. Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Open the flap: 手順 9、 2の画像 1 Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Open the flap: 手順 9、 2の画像 2
    • Use the tip of an opening pick to open the black flap of the ZIF connector by pushing it upwards.
  10. Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Disconnect the interconnect cable: 手順 10、 2の画像 1 Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Disconnect the interconnect cable: 手順 10、 2の画像 2
    この手順で使用する道具:
    • Use your fingers or a pair of blunt nose tweezers to disconnect the interconnect cable from its connector.
  11. Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the front case: 手順 11、 1の画像 1
    • Remove the front case.
  12. Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the screws: 手順 12、 1の画像 1
    • Remove the two 6.8 mm-long screws on the top circuit board using a Phillips screwdriver.
  13. Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Open the ZIF connector: 手順 13、 2の画像 1 Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Open the ZIF connector: 手順 13、 2の画像 2
    • Use a spudger to flip up the locking tab on the ZIF connector.
  14. Nintendo Switch Pro Controller Buttons / D-Pad Replacement: 手順 14、 2の画像 1 Nintendo Switch Pro Controller Buttons / D-Pad Replacement: 手順 14、 2の画像 2
    • Remove the black ribbon cable from its connector.
    • Only a small amount of force should be needed to remove the ribbon cable.
  15. Nintendo Switch Pro Controller Buttons / D-Pad Replacement: 手順 15、 2の画像 1 Nintendo Switch Pro Controller Buttons / D-Pad Replacement: 手順 15、 2の画像 2
    • Remove the trigger buttons from the plastic cover.
  16. Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Unscrew the circuit board: 手順 16、 1の画像 1
    • Use a Phillips screwdriver to remove the two 5 mm-long screw securing the circuit board.
  17. Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the board: 手順 17、 2の画像 1 Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the board: 手順 17、 2の画像 2
    • Remove the circuit board.
  18. Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the button(s): 手順 18、 3の画像 1 Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the button(s): 手順 18、 3の画像 2 Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the button(s): 手順 18、 3の画像 3
    この手順で使用する道具:
    • Use your fingers or a pair of tweezers to remove the button(s) you wish to replace.
終わりに
21 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
James Seidlinger
メンバー登録日: 10/10/19
667 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team S11-G2, Regan Fall 2019 Cal Poly, Team S11-G2, Regan Fall 2019人のメンバー
CPSU-REGAN-F19S11G2
5 メンバー
43のガイドは作成済み
3 件のコメント
On re-assembly, you may have trouble getting the top circuit board and shoulder button support structure to snap into place. It’s easiest to get the circuit board around the right analog stick hole, and push it all the way down until it is in place, then to secure the shoulder button support structure.
Make sure the “Home” button clear plastic light spreader (a clear irregular circle-shaped piece) is in place on top of the home button assembly, or it will give the home button a “sunken” appearance.
nclee - 返信
Worked well, thank you. Had a gooey X button that needed to be cleaned.
Anthony Peacock - 返信
What about the sync button? I've been scouring the Switch Pro Controller guide all day but there's nothing on how to remove the sync button! Mine is in really bad shape from having to use paperclips to press it but i can't find a guide to repair it anywhere.
faye kim - 返信
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 89
過去 30 日: 456
今までの合計 33,936
