メインコンテンツにスキップ
Nintendo Switch 2 Back Cover Replacement
必要な工具と部品
  1. Nintendo Switch 2 Back Cover Replacement, Power off the console: 手順 1、 3の画像 1 Nintendo Switch 2 Back Cover Replacement, Power off the console: 手順 1、 3の画像 2 Nintendo Switch 2 Back Cover Replacement, Power off the console: 手順 1、 3の画像 3
    • For your safety, discharge the battery below 25% before disassembling the console. This reduces the risk of a fire if the battery is damaged during the repair. If the battery is swollen, take appropriate precautions.
    • Remove any game cards and disconnect any cables, controllers, or other accessories from the console.
    • Power off the console by holding down the power button, selecting Power Options, then pressing Power Off.
  2. Nintendo Switch 2 Back Cover Replacement, Remove the bottom screws: 手順 2、 2の画像 1 Nintendo Switch 2 Back Cover Replacement, Remove the bottom screws: 手順 2、 2の画像 2
    • Use a JIS 00 driver to remove the two 3.1 mm‑long screws on either side of the bottom USB-C port.
    • You can try a non-iFixit Phillips driver in a pinch, but you risk damaging or stripping the screw. Push down firmly on the driver and twist slowly.
  3. Nintendo Switch 2 Back Cover Replacement, Remove the top screw: 手順 3、 2の画像 1 Nintendo Switch 2 Back Cover Replacement, Remove the top screw: 手順 3、 2の画像 2
    • Use a JIS 00 driver to remove the 3.1 mm‑long screw on the top edge of the console (next to the ventilation cutouts).
  4. Nintendo Switch 2 Back Cover Replacement, Heat the right side sticker: 手順 4、 1の画像 1
    • The Switch 2 has stickers on either side that need to removed to access the screws securing the back cover. It's easy to damage the stickers during removal, but you can mitigate this by regularly reheating the stickers and working carefully.
    • Use a hair dryer or heat gun to heat the sticker on the right side of the console, labeled with a "+" symbol, until it's hot to the touch.
    • You can use the kickstand to prop the console up vertically for easier access.
    • If you're using a heat gun, set it to low to avoid melting the plastic edge of the console.
  5. Nintendo Switch 2 Back Cover Replacement, Pry up the right side sticker: 手順 5、 3の画像 1 Nintendo Switch 2 Back Cover Replacement, Pry up the right side sticker: 手順 5、 3の画像 2 Nintendo Switch 2 Back Cover Replacement, Pry up the right side sticker: 手順 5、 3の画像 3
    • The pointed end of the tweezers can damage the sticker from the underside, leaving a noticeable mark. If it's difficult to lift, apply more heat instead of using more force.
    • Slide one arm of angled tweezers underneath the sticker from its cutout around the right Joy‑Con 2 connector.
    • Gently pry up on the sticker until it starts to lift from the console.
    • Leave the tweezers in place to keep the sticker lifted.
  6. Nintendo Switch 2 Back Cover Replacement: 手順 6、 3の画像 1 Nintendo Switch 2 Back Cover Replacement: 手順 6、 3の画像 2 Nintendo Switch 2 Back Cover Replacement: 手順 6、 3の画像 3
    この手順で使用する道具:
    Jimmy
    $7.16
    • Insert the tip of a Jimmy into the gap formed between the long edge of the console and the sticker.
    • Gently pry up the sticker, working your way up the long edge until the top of the sticker is separated from the console.
    • Remove the tweezers once the sticker is lifted.
    • You can leave the Jimmy in place to hold the top of the sticker off the frame—if it falls back into its recess, repeat this procedure to lift it back up.
  7. Nintendo Switch 2 Back Cover Replacement, Heat the right side sticker: 手順 7、 1の画像 1
    • Reheat the bottom of the right side until it's hot to the touch.
  8. Nintendo Switch 2 Back Cover Replacement, Remove the right side sticker: 手順 8、 3の画像 1 Nintendo Switch 2 Back Cover Replacement, Remove the right side sticker: 手順 8、 3の画像 2 Nintendo Switch 2 Back Cover Replacement, Remove the right side sticker: 手順 8、 3の画像 3
    • Carefully lift the sticker over the Joy‑Con 2 connector, then peel it up fully to remove it.
  9. Nintendo Switch 2 Back Cover Replacement, Remove the left side sticker: 手順 9、 3の画像 1 Nintendo Switch 2 Back Cover Replacement, Remove the left side sticker: 手順 9、 3の画像 2 Nintendo Switch 2 Back Cover Replacement, Remove the left side sticker: 手順 9、 3の画像 3
    • Repeat this procedure to remove the sticker along the left side of the console, labeled with a "-" symbol.
  10. Nintendo Switch 2 Back Cover Replacement, Remove the side screws: 手順 10、 2の画像 1 Nintendo Switch 2 Back Cover Replacement, Remove the side screws: 手順 10、 2の画像 2
    • Use a JIS 00 driver to remove the two 3.6 mm‑long gold screws on each side of the console (four in total).
  11. Nintendo Switch 2 Back Cover Replacement, Open the kickstand: 手順 11、 3の画像 1 Nintendo Switch 2 Back Cover Replacement, Open the kickstand: 手順 11、 3の画像 2 Nintendo Switch 2 Back Cover Replacement, Open the kickstand: 手順 11、 3の画像 3
    • Use your fingers to flip up the kickstand on the back of the console.
    • If there's a microSD Express card installed, remove it now before you continue to the next step.
  12. Nintendo Switch 2 Back Cover Replacement, Remove the back-side screws: 手順 12、 2の画像 1 Nintendo Switch 2 Back Cover Replacement, Remove the back-side screws: 手順 12、 2の画像 2
    • Use a Y00 driver to remove the two 4.4 mm‑long screws in the kickstand cutout.
  13. Nintendo Switch 2 Back Cover Replacement, Insert an opening pick: 手順 13、 2の画像 1 Nintendo Switch 2 Back Cover Replacement, Insert an opening pick: 手順 13、 2の画像 2
    • Insert an opening pick into the gap between the back cover and speaker cutout on the bottom edge of the console.
  14. Nintendo Switch 2 Back Cover Replacement: 手順 14、 2の画像 1 Nintendo Switch 2 Back Cover Replacement: 手順 14、 2の画像 2
    • Slide the opening pick towards the USB-C port until it's underneath the screw hole next to the port.
  15. Nintendo Switch 2 Back Cover Replacement, Insert a second opening pick: 手順 15、 3の画像 1 Nintendo Switch 2 Back Cover Replacement, Insert a second opening pick: 手順 15、 3の画像 2 Nintendo Switch 2 Back Cover Replacement, Insert a second opening pick: 手順 15、 3の画像 3
    • Insert a second opening pick underneath the screw hole on the opposite side of the USB-C port, and slide it to the corner of the console.
  16. Nintendo Switch 2 Back Cover Replacement: 手順 16、 2の画像 1 Nintendo Switch 2 Back Cover Replacement: 手順 16、 2の画像 2
    • Slide the first opening pick back to where it was first inserted.
  17. Nintendo Switch 2 Back Cover Replacement, Remove the back cover: 手順 17、 3の画像 1 Nintendo Switch 2 Back Cover Replacement, Remove the back cover: 手順 17、 3の画像 2 Nintendo Switch 2 Back Cover Replacement, Remove the back cover: 手順 17、 3の画像 3
    • Be careful not to drop your console. Once the back cover pops up, the opening picks will fall out of place.
    • Hold the console with two hands. Rest your thumbs on the opening picks.
    • Push up on the opening picks to lift the back cover until it pops up above the USB-C port.
  18. Nintendo Switch 2 Back Cover Replacement: 手順 18、 3の画像 1 Nintendo Switch 2 Back Cover Replacement: 手順 18、 3の画像 2 Nintendo Switch 2 Back Cover Replacement: 手順 18、 3の画像 3
    • Lift the back cover up from the bottom edge and remove it.
  19. Nintendo Switch 2 Back Cover Replacement, Disassembly complete: 手順 19、 1の画像 1
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your console.
  20. Nintendo Switch 2 Back Cover Replacement, Prepare the back cover: 手順 20、 3の画像 1 Nintendo Switch 2 Back Cover Replacement, Prepare the back cover: 手順 20、 3の画像 2 Nintendo Switch 2 Back Cover Replacement, Prepare the back cover: 手順 20、 3の画像 3
    • Fully pull out the game card tray.
    • Double-check the power and volume buttons to ensure they're seated correctly. If the rubber membrane beneath the buttons is out of place, ensure it's aligned with its pegs.
    • Check the microphone to ensure it's fully seated in its slot in the frame.
  21. Nintendo Switch 2 Back Cover Replacement, Install the back cover: 手順 21、 3の画像 1 Nintendo Switch 2 Back Cover Replacement, Install the back cover: 手順 21、 3の画像 2 Nintendo Switch 2 Back Cover Replacement, Install the back cover: 手順 21、 3の画像 3
    • Align the top of the back cover with the top of the console.
    • Set the top edge of the back cover into place, checking the buttons and ports to ensure they're aligned properly. If they aren't, lift the back cover and try again.
    • Press along the top edge to fasten the clips securing the back cover to the console.
  22. Nintendo Switch 2 Back Cover Replacement: 手順 22、 2の画像 1 Nintendo Switch 2 Back Cover Replacement: 手順 22、 2の画像 2
    • Squeeze the rest of the back cover and console together to fasten the clips.
  23. Nintendo Switch 2 Back Cover Replacement, Install the back-side screws: 手順 23、 3の画像 1 Nintendo Switch 2 Back Cover Replacement, Install the back-side screws: 手順 23、 3の画像 2 Nintendo Switch 2 Back Cover Replacement, Install the back-side screws: 手順 23、 3の画像 3
    • Use a JIS 00 driver to install the three 3.1 mm‑long screws securing the back cover: one on the top edge of the console, and two on either side of the bottom USB-C port.
    • Use a Y00 driver to install the two 4.4 mm‑long screws in the kickstand cutout.
  24. Nintendo Switch 2 Back Cover Replacement, Install the side screws: 手順 24、 2の画像 1 Nintendo Switch 2 Back Cover Replacement, Install the side screws: 手順 24、 2の画像 2
    • Install the two 3.6 mm‑long gold screws on each side of the console (four in total).
  25. Nintendo Switch 2 Back Cover Replacement, Test the console: 手順 25、 2の画像 1 Nintendo Switch 2 Back Cover Replacement, Test the console: 手順 25、 2の画像 2
    • Power on the console and test functionality to ensure it's working as expected.
  26. Nintendo Switch 2 Back Cover Replacement, Install the stickers: 手順 26、 3の画像 1 Nintendo Switch 2 Back Cover Replacement, Install the stickers: 手順 26、 3の画像 2 Nintendo Switch 2 Back Cover Replacement, Install the stickers: 手順 26、 3の画像 3
    • Align the right side sticker with its recess. Ensure the cutout in the sticker is aligned with the Joy-Con connector.
    • Set the sticker into its recess, first on one side, then the other.
    • Use your finger or the flat end of a spudger to press the sticker into place.
    • If the sticker isn't sticking well, apply heat after you press it into place.
  27. Nintendo Switch 2 Back Cover Replacement: 手順 27、 3の画像 1 Nintendo Switch 2 Back Cover Replacement: 手順 27、 3の画像 2 Nintendo Switch 2 Back Cover Replacement: 手順 27、 3の画像 3
    • Repeat this procedure to install the left side sticker.
終わりに
You finished fixing your Switch 2!
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch 2 Answers Community for help.
Nick Schultz
メンバー登録日: 03/24/24
36,957 ポイント
224のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 9
過去 7 日: 70
過去 30 日: 325
今までの合計 1,262
