メインコンテンツにスキップ
Nintendo GameCube Controller Rumble Motor Replacement
必要な工具と部品
  1. Nintendo GameCube Controller Rumble Motor Replacement, Back Panel: 手順 1、 1の画像 1
    • Place the controller (buttons down) on a solid surface.
    • Remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
  2. Nintendo GameCube Controller Rumble Motor Replacement: 手順 2、 1の画像 1
    • Gently lift the back panel up, separating it from the front panel.
    • Some of the buttons may fall out if they are knocked around.
  3. Nintendo GameCube Controller Rumble Motor Replacement, Z Button: 手順 3、 2の画像 1 Nintendo GameCube Controller Rumble Motor Replacement, Z Button: 手順 3、 2の画像 2
    • Grab the Z-button by the peg with tweezers and lift it out of the controller.
    • During re-assembly, make sure the plastic rim and spring fit into the slot provided, or else the case will not shut.
  4. Nintendo GameCube Controller Rumble Motor Replacement, Circuit Board: 手順 4、 1の画像 1
    • Carefully unhook the cable that is looped around the peg.
  5. Nintendo GameCube Controller Rumble Motor Replacement: 手順 5、 1の画像 1
    • Lift the circuit board out of the controller.
    • Do not grab the rumble motor to lift the circuit board as shown in the picture. It will in many cases just remove the rumble motor. Instead, grab the edges of the board.
  6. Nintendo GameCube Controller Rumble Motor Replacement, Rumble Motor: 手順 6、 2の画像 1 Nintendo GameCube Controller Rumble Motor Replacement, Rumble Motor: 手順 6、 2の画像 2
    • Press the tip of the soldering iron against one of the leads and wait until solder is viscous. Carefully pull wire away from lead.
    • Repeat for the second lead and wire.
    • During reassembly, solder the white wire to (+) lead on the right side, and the black wire to the (-) lead on the left side.
    • For more information, please refer to this soldering guide.
  7. Nintendo GameCube Controller Rumble Motor Replacement: 手順 7、 1の画像 1
    この手順で使用する道具:
    • Using tweezers, unhook the wires from the small black bracket keeping them attached to the circuit board.
  8. Nintendo GameCube Controller Rumble Motor Replacement: 手順 8、 1の画像 1
    • Lift the motor out of the bracket.
    • Remember to not pull by the wires! This can make your repair a lot more complicated.
終わりに
3 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Sean Michel
メンバー登録日: 01/14/13
2,600 ポイント
8のガイドは作成済み
チーム
Cal Poly, Team 19-44, Regan Winter 2013 Cal Poly, Team 19-44, Regan Winter 2013人のメンバー
CPSU-REGAN-W13S19G44
4 メンバー
32のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 24
過去 30 日: 199
今までの合計 16,746
