この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Reaching the desired temperature on your Ninja Foodi SP101 is an essential feature. The temperature sensor inside the device regulates temperature and the cooling fan. The inability to reach high temperatures on your Foodi may be due to a malfunctioning temperature sensor.
必要な工具と部品
Use a Phillips #1 screwdriver to remove the three 8mm screws on each side of the back panel.
The temperature sensor is found under the handle side panel.
The sensor is held down by a rivet. Here is a guide to removing rivets.
