メインコンテンツにスキップ
Nikon D7000 Mirror Box & Viewfinder Replacement
必要な工具と部品
  1. Nikon D7000 Mirror Box & Viewfinder Replacement, Motherboard: 手順 1、 1の画像 1
    • When loosening the screws, start pressing the screwdriver firmly for the first 1-2 turns (highest torque) until the screw is 'unlocked'. Failing to do so can damage the screw head and make it impossible to disengage that screw.
    • Remove the following 5 screws securing the bottom cover to the camera body:
    • Four 6 mm J000 screws.
    • One 8 mm J000 screw (under lens mount).
  2. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 2、 1の画像 1
    • Remove three 6 mm J000 screws from under the battery cover.
  3. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 3、 2の画像 1 Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 3、 2の画像 2
    • Gently pull the bottom cover off of the camera body.
  4. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 4、 1の画像 1
    • Remove the following screws from the port area:
    • Two 3.5 mm J000 screws.
    • One 6 mm J000 screw (right above ports).
  5. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 5、 1の画像 1
    この手順で使用する道具:
    • Peel the rear rubber piece off with tweezers.
  6. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 6、 1の画像 1
    • Remove one 4.25 mm J000 screw from behind the rear rubber piece.
  7. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 7、 1の画像 1
    • Pull the eyepiece cover up to remove it.
  8. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 8、 1の画像 1
    • Remove two 6 mm J000 screws from behind the eyepiece cover.
    • On D7100 models, there is an additional screw holding the back plate on. This screw is located in the diopter (dial with + - on it). This screw can be accessed by peeling up this sticker on the diopter.
  9. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 9、 1の画像 1
    • Open the SD card cover by pushing slightly down with your thumb and sliding up.
  10. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 10、 1の画像 1
    • Remove four 6 mm J000 screws that secure the SD card cover.
  11. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 11、 1の画像 1
    • Gently pull the SD card cover off.
  12. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 12、 1の画像 1
    • Remove the following screws that secure the back case:
    • One 6 mm J000 screw.
    • One 3 mm J000 screw.
  13. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 13、 1の画像 1
    • Carefully lift the back case off.
  14. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 14、 3の画像 1 Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 14、 3の画像 2 Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 14、 3の画像 3
    • Disconnect the following two ribbon cables from the motherboard.
    • See our Cable Connector Guide for help with ribbon cable connectors!
  15. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 15、 2の画像 1 Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 15、 2の画像 2
    • Remove the following screws securing the left motherboard shield:
    • One 2 mm J000 screw (on the bottom).
    • One 3.5 mm J000 screw (on the back).
    • Be careful of the grounding clips on the motherboard.
  16. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 16、 1の画像 1
    • Gently pry and lift the left motherboard shield off.
  17. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 17、 1の画像 1
    • Remove one 3.5 mm J000 screw securing the right motherboard shield.
  18. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 18、 1の画像 1
    • Gently lift the right motherboard shield off with the tip of a spudger.
  19. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 19、 3の画像 1 Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 19、 3の画像 2 Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 19、 3の画像 3
    • Disconnect remaining ribbon cables.
  20. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 20、 2の画像 1 Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 20、 2の画像 2
  21. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 21、 1の画像 1
    • Carefully disconnect the red connector with tweezers.
  22. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 22、 1の画像 1
    • Remove four 3.5 mm J000 screws securing the motherboard.
  23. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 23、 1の画像 1
    • Gently pull the port side cover away from the motherboard.
  24. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 24、 1の画像 1
    • Lift the motherboard off.
  25. Nikon D7000 Mirror Box & Viewfinder Replacement, Tripod Plate: 手順 25、 1の画像 1
    • Remove four 6 mm J000 screws securing the tripod plate.
  26. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 26、 1の画像 1
    • Carefully lift the tripod plate from the backside of the camera and slide out the grounding clip from under the lens mount.
  27. Nikon D7000 Mirror Box & Viewfinder Replacement, Image Sensor: 手順 27、 2の画像 1 Nikon D7000 Mirror Box & Viewfinder Replacement, Image Sensor: 手順 27、 2の画像 2
    • Disconnect black and white speaker cable.
  28. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 28、 1の画像 1
    • Remove three 6 mm J000 screws securing the image sensor.
  29. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 29、 1の画像 1
    • Carefully lift the image sensor plate out of the camera.
  30. Nikon D7000 Mirror Box & Viewfinder Replacement, Shutter Assembly: 手順 30、 1の画像 1
    • Manually pop up flash by inserting a screw driver to the left of the viewfinder and pressing on the metal lever.
    • It won't take much pressure. Press carefully and the flash will pop up when you find the right spot.
  31. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 31、 1の画像 1
    • Remove two 5 mm J000 screws from under the flash.
  32. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 32、 1の画像 1
    • Remove two 3 mm J000 screws securing the front cover.
  33. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 33、 2の画像 1 Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 33、 2の画像 2
    • Remove the front cover.
  34. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 34、 1の画像 1
    • Carefully remove the port cover.
  35. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 35、 1の画像 1
    • Deroute the microphone cable.
  36. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 36、 1の画像 1
    • Remove one 4 mm J000 screw from the front.
  37. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 37、 1の画像 1
    • Remove one 8.5 mm J000 screw from the battery compartment.
  38. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 38、 1の画像 1
    • Remove the grip carefully.
  39. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 39、 1の画像 1
    • Remove one 4 mm J000 screw securing the top case (under right strap hook).
  40. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 40、 1の画像 1
    • Remove one 4 mm J000 screw securing the top case (under left strap hook).
  41. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 41、 1の画像 1
    • Remove the sticker covering the diopter adjust screw.
  42. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 42、 1の画像 1
    • Remove one 8.0 mm J000 screw.
    • Remove the Diopeter Adjust.
  43. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 43、 1の画像 1
    • Remove the top case.
  44. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 44、 1の画像 1
    • Remove the Black, Yellow, Green cable from the top case board.
  45. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 45、 3の画像 1 Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 45、 3の画像 2 Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 45、 3の画像 3
    • Remove two 6.5 mm J000 screws securing the viewfinder.
    • Remove the viewfinder cover.
  46. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 46、 1の画像 1
    • Remove one 3 mm J000 screw from the bottom left side of the camera.
  47. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 47、 1の画像 1
    • Remove two 6 mm J000 screws from the left of the shutter.
  48. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 48、 1の画像 1
    • Remove two 6.5 mm J000 screws from beneath the lens mount.
  49. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 49、 1の画像 1
    • Remove two screws from just below and to the sides of the viewfinder.
  50. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 50、 1の画像 1
    • Remove one 5 mm J000 screw from the top right of the camera.
  51. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 51、 1の画像 1
    • Carefully peel back ribbon cable on the bottom left of camera.
  52. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 52、 2の画像 1 Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 52、 2の画像 2
    • Remove the left front ribbon cable from top right of circuit board.
  53. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 53、 1の画像 1
    • Remove all three wire connectors.
  54. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 54、 1の画像 1
    • Separate the shutter assembly from the camera body.
  55. Nikon D7000 Mirror Box & Viewfinder Replacement, Mirror Box & Viewfinder: 手順 55、 1の画像 1
    • Pull out ribbon cable from circuit asembly near front left of device.
  56. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 56、 1の画像 1
    • Desolder red & black power leads.
    • Check out our soldering guide for help!
  57. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 57、 1の画像 1
    • Disconnect ribbon cable at the top right of camera.
  58. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 58、 1の画像 1
    • Disconnect ribbon cable at top right of camera.
  59. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 59、 1の画像 1
    • Disconnected ribbon cable at rear right of viewfinder.
  60. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 60、 1の画像 1
    • Remove the two 5.5mm J000 screws
  61. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 61、 1の画像 1
    • Remove the 5.5 mm J000 screw.
  62. Nikon D7000 Mirror Box & Viewfinder Replacement: 手順 62、 1の画像 1
    • Remove the viewfinder from the mirror box assembly.
終わりに
5 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Thomas Willson
メンバー登録日: 04/02/15
450 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 24-6, Lancaster Spring 2015 Cal Poly, Team 24-6, Lancaster Spring 2015人のメンバー
CPSU-LANCASTER-S15S24G6
3 メンバー
5のガイドは作成済み
コメント 1 件
now I know why my camera failed,, the motor overheated
sir francis - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 16
過去 30 日: 83
今までの合計 12,723
