メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Nikon D3000 On/Off Switch and Shutter Button Replacement
必要な工具と部品
    1. Nikon D3000 On/Off Switch and Shutter Button Replacement, On/Off Switch and Shutter Button: 手順 1、 2の画像 1 Nikon D3000 On/Off Switch and Shutter Button Replacement, On/Off Switch and Shutter Button: 手順 1、 2の画像 2
      • Remove six 3 mm x 2.5 mm Phillips head screws from the bottom of the camera.
      • Remove three 3 mm x 5.5 mm Phillips head screws from the bottom of the camera near the battery cover.
      • Lift the battery cover and remove two 3 mm x 5.5 mm Phillips head screws as shown.
      • Remove the bottom cover.
      FixBotに聞いてみる
      コメントを追加
    2. Nikon D3000 On/Off Switch and Shutter Button Replacement: 手順 2、 3の画像 1 Nikon D3000 On/Off Switch and Shutter Button Replacement: 手順 2、 3の画像 2 Nikon D3000 On/Off Switch and Shutter Button Replacement: 手順 2、 3の画像 3
      • Remove two 3 mm x 5.5 mm Phillips head screws from either side of the viewfinder.
      • Remove four 3 mm x 5.5 mm Phillips head screws above and below the USB port cover and on either side of the SD card slot cover.
      • Remove two 3 mm x 4 mm Phillips head screws inside the SD card slot cover.
      FixBotに聞いてみる
      コメントを追加
    3. Nikon D3000 On/Off Switch and Shutter Button Replacement: 手順 3、 2の画像 1 Nikon D3000 On/Off Switch and Shutter Button Replacement: 手順 3、 2の画像 2
      • Lift the LCD panel off up to expose a ribbon connector. Then lift the ribbon connector tab as shown and slide the ribbon out.
      • Use this technique for all ribbon connectors in this guide.
      • Lift the LCD panel away and off the camera
      FixBotに聞いてみる
      コメントを追加
    4. Nikon D3000 On/Off Switch and Shutter Button Replacement: 手順 4、 2の画像 1 Nikon D3000 On/Off Switch and Shutter Button Replacement: 手順 4、 2の画像 2
      • Remove six 3 mm x 5.5 mm Phillips head screws from around the lens ring and remove the lens ring.
      • Remove two 2.5 mm x 4 mm Phillips head screws from above the lens ring to allow the front of the camera to be removed.
      • Lift and remove the grip and the front panel of the camera.
      FixBotに聞いてみる
      コメントを追加
    5. Nikon D3000 On/Off Switch and Shutter Button Replacement: 手順 5、 3の画像 1 Nikon D3000 On/Off Switch and Shutter Button Replacement: 手順 5、 3の画像 2 Nikon D3000 On/Off Switch and Shutter Button Replacement: 手順 5、 3の画像 3
      • Remove two 3 mm x 4 mm Phillips head screws from where the camera grip was just removed.
      • Remove one 2 mm x 3 mm Phillips head screw from the same location as above.
      • Remove one 3 mm x 5.5 mm Phillips head screw from the top right side of the camera shown.
      • Remove one 3 mm x 3 mm Phillips head screw from the top left side of the camera shown.
      • Gently lift the top of the camera up to separate it from the main body of the camera. At this point, it will still be connected via wires.
      FixBotに聞いてみる
      コメントを追加
    6. Nikon D3000 On/Off Switch and Shutter Button Replacement: 手順 6、 1の画像 1
      • Soldering irons are hot. Take all necessary precautions before soldering to prevent damage to the camera or yourself.
      • De-solder the wire shown on the grip side of the camera to allow sufficient access to the top of the camera.
      FixBotに聞いてみる
      コメントを追加
    7. Nikon D3000 On/Off Switch and Shutter Button Replacement: 手順 7、 2の画像 1 Nikon D3000 On/Off Switch and Shutter Button Replacement: 手順 7、 2の画像 2
      • Remove the ribbon connector.
      • Remove the 3 mm x 4 mm Phillips head screw and lift off the plastic bracket to expose the on/off switch underneath.
      • A quick inspection should take place before replacing the button and the metal contacts.
      • Remove the two 2 mm x 4 mm Phillips head screws and the shutter button and on/off switch will fall down away from the top of the panel.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
4 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Randall Heath
メンバー登録日: 08/25/15
899 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 14-7, Meier Fall 2015 USF Tampa, Team 14-7, Meier Fall 2015人のメンバー
USFT-MEIER-F15S14G7
4 メンバー
6のガイドは作成済み
1件のガイドコメント
Thanks for the guide. It was very helpful. I had problem with a shutter button. I have not replace it but disassembled and cleaned two tiny metal contacts inside, now my camera works well.
rsa91 - 返信 共有
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 12
過去 30 日: 50
今までの合計 5,730
