メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Nikon D3000 LCD Screen Replacement
必要な工具と部品
    1. Nikon D3000 LCD Screen Replacement, LCD Screen: 手順 1、 1の画像 1
      • Removal of the screws from the bottom will aid in the removal of the back as it loosens the bottom tabs of the camera back.
      • Remove three 3 mm x 2.5 mm Phillips head screws from the bottom right back of the camera bottom.
      • Remove one 3 mm x 5.5 mm Phillips head screw from the bottom left of the camera bottom.
      FixBotに聞いてみる
      コメントを追加
    2. Nikon D3000 LCD Screen Replacement: 手順 2、 3の画像 1 Nikon D3000 LCD Screen Replacement: 手順 2、 3の画像 2 Nikon D3000 LCD Screen Replacement: 手順 2、 3の画像 3
      • Remove two 3 mm x 5.5 mm Phillips head screws from either side of the viewfinder.
      • Remove four 3 mm x 5.5 mm Phillips head screws above and below the USB port cover and above and below the SD card slot cover.
      • Remove two 3 mm x 4 mm Phillips head screws inside the SD card slot cover.
      FixBotに聞いてみる
      コメントを追加
    3. Nikon D3000 LCD Screen Replacement: 手順 3、 3の画像 1 Nikon D3000 LCD Screen Replacement: 手順 3、 3の画像 2 Nikon D3000 LCD Screen Replacement: 手順 3、 3の画像 3
      • Gently lift the back of the camera off, starting with the top first.
      • Lift off the bottom slightly to expose the ribbon connector connecting the back of the LCD screen to the motherboard of the camera and lift the black tab on the ribbon connector.
      • Pull the ribbon away from the connector to disconnect the back panel from the main body of the camera.
      FixBotに聞いてみる
      コメントを追加
    4. Nikon D3000 LCD Screen Replacement: 手順 4、 2の画像 1 Nikon D3000 LCD Screen Replacement: 手順 4、 2の画像 2
      • Use the black plastic spudger to push the black tab towards the lower ribbon. The black tab on the smaller ribbon should slide out of place.
      • Lift the white tab on the larger ribbon.
      • Gently disconnect both ribbons.
      FixBotに聞いてみる
      コメントを追加
    5. Nikon D3000 LCD Screen Replacement: 手順 5、 2の画像 1 Nikon D3000 LCD Screen Replacement: 手順 5、 2の画像 2
      • Remove six 5 mm x 4mm Phillips head screws , then remove the metal plate housing the LCD from the plastic camera backing.
      FixBotに聞いてみる
      コメントを追加
    6. Nikon D3000 LCD Screen Replacement: 手順 6、 2の画像 1 Nikon D3000 LCD Screen Replacement: 手順 6、 2の画像 2
      • Cover the old LCD Screen with tape before removing to avoid broken glass if the screen cracks during removal.
      • Use the metal spudger to detach the LCD screen from the metal plate that is held down by the adhesive.
      • Install new LCD screen
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
10 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Randall Heath
メンバー登録日: 08/25/15
899 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 14-7, Meier Fall 2015 USF Tampa, Team 14-7, Meier Fall 2015人のメンバー
USFT-MEIER-F15S14G7
4 メンバー
6のガイドは作成済み
2件のガイドコメント
Completed this project but now my camera doesn’t turn on. Advice?
Eddie Martinez - 返信 共有
My D3000 camera will not display. I change the screen but it still will not display pls help what will i do now
emmanuel nwokocha - 返信 共有
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 21
過去 30 日: 87
今までの合計 12,558
