はじめに
Removing your memory card will allow you to replace it with a new one, access the S9700's internal memory, or remove the current data from it. It does not require extensive knowledge or special tools.
Power off the S9700 and situate it so that it is upside down.
Place your finger on the compartment door.
Gently push toward the front of the S9700.
The compartment door should spring open by itself.
