はじめに
The purpose of this guide is to replace the eyepiece (plastic rectangular piece around the viewfinder) of a Nikon Coolpix P90 if it is loose, broken, or lost.
In steps 1-2, 5, and 8, a Phillips #000 Precision Screwdriver is used to unscrew and remove all of the screws mentioned.
In steps 3-4, 6-7, and 9, there are three data connection ribbons which need to be carefully removed before the repair can continue. Failure to remove these ribbons properly will result in them becoming damaged or ripped, thereby permanently damaging your camera. So, please be careful and go slowly during this repair.
必要な工具と部品
Use your finger to push the latch of the compartment door to the center of the camera body, per image 1.
Push the door open, and remove the existing battery with your fingers, per images 2-3.
On the bottom side of the camera, unscrew both 4.5 mm screws holding the bottom into place, per image 1.
On the right side of the camera, unscrew both 4.5 mm screws holding the side into place, per image 2.
On the right side of the camera, unscrew the 4.5 mm screw underneath the A/V flap, per image 2.
On the top side of the camera, unscrew the 4.0 mm screw on the left-side wrist strap loop, per image 3.
ある他の人がこのガイドを完成しました。
