メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Nikon Coolpix L330 LCD Screen Replacement
必要な工具と部品
    1. Nikon Coolpix L330 LCD Screen Replacement, Back Housing: 手順 1、 3の画像 1 Nikon Coolpix L330 LCD Screen Replacement, Back Housing: 手順 1、 3の画像 2 Nikon Coolpix L330 LCD Screen Replacement, Back Housing: 手順 1、 3の画像 3
      • There are six screws attaching the back housing to the camera. Remove the screws from the body with a PH000 screw head.
      • Two 1.5x2.5mm screws on the right side.
      • Two 1.5x2.5mm screws on the underside.
      • Two 1.5x2.5mm screw on the left side.
      FixBotに聞いてみる
      コメントを追加
    2. Nikon Coolpix L330 LCD Screen Replacement: 手順 2、 2の画像 1 Nikon Coolpix L330 LCD Screen Replacement: 手順 2、 2の画像 2
      • After removing the screws, use a metal spudger or plastic opening tool to push the back cover out.
      • The metal spudger can damage the plastic housing, so use caution when applying any pressure to it. Use a plastic opening tool to reduce the risk of damage to the housing.
      • Remove the back housing of the camera by lifting it directly up.
      • The back cover may be slightly tight, therefore more force may be needed to lift it up.
      FixBotに聞いてみる
      コメントを追加
    1. Nikon Coolpix L330 LCD Screen Replacement, LCD Screen: 手順 3、 2の画像 1 Nikon Coolpix L330 LCD Screen Replacement, LCD Screen: 手順 3、 2の画像 2
      • Insert the tips of your fingers into the space between the screen and back-plate.
      • Gently lift the screen up and out of the frame.
      • The screen is still held by a flexible display cable, therefore only lift the screen 0.5'' out of the back-plate.
      FixBotに聞いてみる
      コメントを追加
    2. Nikon Coolpix L330 LCD Screen Replacement: 手順 4、 2の画像 1 Nikon Coolpix L330 LCD Screen Replacement: 手順 4、 2の画像 2
      • Tilt the screen so that the display cable forms a hinge with the backplate.
      • Rotate the display 180 degrees so that it faces you.
      FixBotに聞いてみる
      コメントを追加
    3. Nikon Coolpix L330 LCD Screen Replacement: 手順 5、 3の画像 1 Nikon Coolpix L330 LCD Screen Replacement: 手順 5、 3の画像 2 Nikon Coolpix L330 LCD Screen Replacement: 手順 5、 3の画像 3
      • The display cable has a ZIF (zero insertion force) connector on the end. This has a tab that has to be pushed out before the cable can be safely removed.
      • Using a plastic opening tool or fingernail, pop up the black clip holding the display cable. This will release the cable.
      • Slide the display cable out of the connector.
      • The display cable can be damaged due to excessive bending, therefore avoid putting unnecessary strain on it.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
5 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Rajeev
メンバー登録日: 02/09/16
623 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 2-10, Cagle Spring 2016 USF Tampa, Team 2-10, Cagle Spring 2016人のメンバー
USFT-CAGLE-S16S2G10
4 メンバー
14のガイドは作成済み
1件のガイドコメント
Thank you, saved me money and time
Mihai Alexandru Fustos - 返信 共有
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 13
過去 30 日: 38
今までの合計 2,460
