メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Nexus 6 Front Facing Camera Replacement
必要な工具と部品
  1. Nexus 6 Front Facing Camera Replacement, SIM Card: 手順 1、 1の画像 1
    • With a SIM card eject tool (a paperclip will work as well), push down on the hole at the top of the phone until the SIM card holder releases. This should not take much pressure.
    • Remove the SIM card and the SIM card holder.
  2. Nexus 6 Front Facing Camera Replacement, Rear Case: 手順 2、 2の画像 1 Nexus 6 Front Facing Camera Replacement, Rear Case: 手順 2、 2の画像 2
    この手順で使用する道具:
    iOpener
    $14.99
    • Lay out a soft cloth on your workspace to prevent scratching the screen in this and future steps.
    • Pry open the back casing using the soft plastic opening pick.
    • Be careful of the Power & Volume Key ribbon on the left side just next to the volume key. The ribbon is exposed and could be damaged with the opening tool.
    • Carefully pull the back casing apart from the rest of the phone with your hands. Because the casing is glued to the rest of the phone, this step may require some force. Don't be alarmed if the casing flexes a bit.
    • You may need an iOpener to loosen up the adhesive. Check out the iOpenerの使用方法 for info on how to use it.
  3. Nexus 6 Front Facing Camera Replacement: 手順 3、 1の画像 1
    • Remove the twenty-two 2.3 mm T3 Torx screws with the T3 Torx Screwdriver.
  4. Nexus 6 Front Facing Camera Replacement: 手順 4、 3の画像 1 Nexus 6 Front Facing Camera Replacement: 手順 4、 3の画像 2 Nexus 6 Front Facing Camera Replacement: 手順 4、 3の画像 3
    この手順で使用する道具:
    • With tweezers, remove the rubber protector on the lower part of the phone.
    • Disconnect the battery connector by gently prying it straight up with a spudger, on the side opposite the cable.
    • Completely separate the battery side from the motherboard side by gently pulling the sides apart with your hands.
  5. Nexus 6 Front Facing Camera Replacement, Front Facing Camera: 手順 5、 1の画像 1
    この手順で使用する道具:
    • Use a spudger to gently detach the front facing camera connector.
    • Remove the front facing camera using the tweezers.
終わりに
5 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Marina Moore
メンバー登録日: 01/13/15
4,302 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 70-3, Forte Winter 2015 Cal Poly, Team 70-3, Forte Winter 2015人のメンバー
CPSU-FORTE-W15S70G3
4 メンバー
30のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 64
今までの合計 2,728
