メインコンテンツにスキップ
Nest x Yale Lock Deadbolt Button Replacement
必要な工具と部品
  1. Nest x Yale Lock Deadbolt Button Replacement, Motherboard: 手順 1、 1の画像 1
    • Before proceeding, make sure the batteries are removed to avoid being electrocuted and damage to the lock
    • If you do not know how to remove the batteries then I would recommend looking at our battery replacement guide for help.
  2. Nest x Yale Lock Deadbolt Button Replacement: 手順 2、 2の画像 1 Nest x Yale Lock Deadbolt Button Replacement: 手順 2、 2の画像 2
    • Remove 3 screws as shown to remove the first cover.
    • The 3 screws are 0.25 inches length
  3. Nest x Yale Lock Deadbolt Button Replacement: 手順 3、 1の画像 1
    • Using a pin to push down the knot holding the wire and the tweezer to safely remove the wire from the motherboard
  4. Nest x Yale Lock Deadbolt Button Replacement: 手順 4、 2の画像 1 Nest x Yale Lock Deadbolt Button Replacement: 手順 4、 2の画像 2
    この手順で使用する道具:
    購入する
    • Use a spudger or plastic tool to lift the ZIF lock upward (as shown in the first picture).
    • Use tweezers to remove the ribbon cable from the motherboard.
  5. Nest x Yale Lock Deadbolt Button Replacement: 手順 5、 1の画像 1
    • Continue to remove 2 screws holding the motherboard to the lock shell.
    • The screws are 0.20 inches in length.
  6. Nest x Yale Lock Deadbolt Button Replacement: 手順 6、 2の画像 1 Nest x Yale Lock Deadbolt Button Replacement: 手順 6、 2の画像 2
    • Use an opening tool to push the motherboard out as shown in the picture.
  7. Nest x Yale Lock Deadbolt Button Replacement, Deadbolt Button: 手順 7、 2の画像 1 Nest x Yale Lock Deadbolt Button Replacement, Deadbolt Button: 手順 7、 2の画像 2
    • After, fully removing the motherboard.
    • Remove the .25 in screws circled in red to remove the lock compartment.
    • Lastly, take out the lock as shown in the second picture.
  8. Nest x Yale Lock Deadbolt Button Replacement: 手順 8、 1の画像 1
    • Move onto removing the .25 inches screws in red to take out the battery holder.
    • Remove the .15 inches screws in orange as well.
  9. Nest x Yale Lock Deadbolt Button Replacement: 手順 9、 2の画像 1 Nest x Yale Lock Deadbolt Button Replacement: 手順 9、 2の画像 2
    • After unscrewing the battery holder you can now see the lights circled in red
    • The part squared in orange is a rubber that reflects the light of the LED.
終わりに
作成者
3人の作成者と共同で作成されました。
Christopher Gonzalez
メンバー登録日: 09/26/22
313 ポイント
3のガイドは作成済み
チーム
CSU Los Angeles, Team 5-3, Adachi Fall 2022 CSU Los Angeles, Team 5-3, Adachi Fall 2022人のメンバー
CSULA-ADACHI-F22S5G3
5 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 28
今までの合計 474
