はじめに
If the doorbell button on your Nest Hello is cracked or leaking, this guide will help you access and replace it. During disassembly, it is easy to damage the waterproofing O-Ring, so plan on replacing that as well. This does involve removing all of the internals from the device using the iFixit opening picks, Phillips #000 screwdriver, and tweezers. Be sure to take your time and keep track of screws and other parts.
必要な工具と部品
Insert the pick between the black faceplate and white casing of the Nest Hello.
Pry the faceplate away from the device with the opening pick.
Completely remove the faceplate from the device, do not be afraid to pull hard.
Use the Phillips #000 to remove the two screws holding the ribbon cable to the white casing.
Once the circuitboard is free from the plastic housing, the button can be removed by pushing on it from the front side.
ある他の人がこのガイドを完成しました。
2件のガイドコメント
Where do you get the parts. Google is no help. I’m trying to get the black faceplate from your first step. I can’t find it.
Ryan Gauder - 返信 共有
Where do I buy a button?
Joel Lundi - 返信 共有
