はじめに
This guide will help you strip down the gun to the trigger. You will need a screwdriver and, if necessary, a replacement trigger.
必要な工具と部品
Using a screwdriver, carefully unscrew the three #00 1 cm Phillips screws holding the two slide pieces together.
Remove the twelve #00 1 cm Phillips screws.
Rotate the gun so that the front is facing you to remove the final screw.
Lift the outside cover off of the gun. Only the side where you removed the screws will come off.
Remove the seven #00 1 cm Phillips screws that attach the inner mechanism to the back cover.
Remove the #00 1.2 cm Phillips screw located to the right of the white casing.
Wiggle the front cover out from under the white piece and lift up from the gun.
Disconnect the inner mechanism from the outer cover by lifting the inner mechanism towards you.
Flip over the inner mechanism.
Remove the two #00 1 cm Phillips screws that hold the trigger in place.
Slightly lift the area of the trigger that had the screw towards you, and rotate the trigger counter-clockwise.
6 の人々がこのガイドを完成させました。
