このバージョンは誤った内容を含んでいる可能性があります。最新の承認済みスナップショットに切り替えてください。
必要な工具と部品
この手順は未翻訳です。 翻訳を手伝う。
Before soldering the black wire onto the motor clean your soldering iron. Do this by tinning it a little bit as you see in pic 1 then wipe it off on the damp sponge.
After tinning your soldering iron you want to tin your wire to make sure the threads won't fall apart as shown in pic 2.
この手順は未翻訳です。 翻訳を手伝う。
この手順で使用する道具:Desoldering Pump$3.99-
For this step you will need your soldering iron, damp sponge, and solder.
If you have a cold joint then you will need the solder sucker, but if the joint is good, meet the wire and the solder at the location of where you want to solder.
Now use your soldering iron to melt the solder onto the wire. Let it dry for 10 sec then tug on the wire gently to see if it worked.
When you tug on it and it breaks loose, use the solder sucker to remove the old solder from the joint and re-solder it. If you tug and nothing happens you are all good.
2 の人々がこのガイドを完成させました。
