メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Nabi Big Tab HD24 Power Button Replacement
必要な工具と部品
  1. Nabi Big Tab HD24 Power Button Replacement, Back Assembly: 手順 1、 1の画像 1
    • Ensure that the tablet is facing you with the screen on the table.
    • Locate the four red rubber stops at the corners.
    FixBotに聞いてみる
    コメントを追加
  2. Nabi Big Tab HD24 Power Button Replacement: 手順 2、 1の画像 1
    • Use your fingers to carefully peel them off the device to reveal the screws underneath.
    FixBotに聞いてみる
    コメントを追加
  3. Nabi Big Tab HD24 Power Button Replacement: 手順 3、 1の画像 1
    • Use a Phillips #1 screwdriver to remove the 9.5 mm screw in each of the four corners.
    FixBotに聞いてみる
    コメントを追加
  4. Nabi Big Tab HD24 Power Button Replacement: 手順 4、 1の画像 1
    • Flip the tablet over such that the screen is facing upwards.
    • Locate the the 4 small openings on the sides of the tablet.
    • There should be 2 on the bottom of the tablet, 1 on each side of the tablet viewing it from the front as if you were using it.
    • Do not confuse the openings with the charging port or the USB ports. The openings will be labelled with an icon of a small fan, the Nabi logo.
    FixBotに聞いてみる
    コメントを追加
  5. Nabi Big Tab HD24 Power Button Replacement: 手順 5、 1の画像 1
    • Insert a metal spudger into one of the openings and carefully pop the device open by applying a steady downward force.
    • Repeat for the other three openings.
    FixBotに聞いてみる
    コメントを追加
  6. Nabi Big Tab HD24 Power Button Replacement: 手順 6、 2の画像 1 Nabi Big Tab HD24 Power Button Replacement: 手順 6、 2の画像 2
    • Flip the device over so that the back assembly is facing you.
    • Use a plastic opening tool to carefully pry open the device from its hinges.
    • Take care when opening the device as there are cables running internally that are connected to both the front and the back assemblies.
    FixBotに聞いてみる
    コメントを追加
  7. Nabi Big Tab HD24 Power Button Replacement: 手順 7、 2の画像 1 Nabi Big Tab HD24 Power Button Replacement: 手順 7、 2の画像 2
    • Locate the white port that connects the back panel to the circuit board on the back of the display.
    • Carefully pull the plastic connector straight out.
    FixBotに聞いてみる
    コメントを追加
  8. Nabi Big Tab HD24 Power Button Replacement: 手順 8、 1の画像 1
    • Be careful of the aluminum foil tape, as it can easily rip.
    • Carefully lift up the aluminum foil tape with your fingers so that the ribbon connector reveals itself.
    • Do not try to pull the ribbon cables off the screen as there is a plastic piece surrounding the ribbon cables glued onto the metal display.
    FixBotに聞いてみる
    コメントを追加
  9. Nabi Big Tab HD24 Power Button Replacement: 手順 9、 1の画像 1
    • Firmly press the two switches located on the sides of the connector and disconnect the connector from its connections.
    • Leave the connector disconnected but still intact with the metal display.
    FixBotに聞いてみる
    コメントを追加
  10. Nabi Big Tab HD24 Power Button Replacement: 手順 10、 1の画像 1
    • Use a plastic opening tool and carefully push it underneath the grey plastic case surrounding the ribbon cable.
    • Apply a downward force to carefully peel the grey plastic off of the metal display.
    FixBotに聞いてみる
    コメントを追加
  11. Nabi Big Tab HD24 Power Button Replacement: 手順 11、 1の画像 1
    • Locate the two cables running on both sides of the device found at the bottom side of the screen.
    FixBotに聞いてみる
    コメントを追加
  12. Nabi Big Tab HD24 Power Button Replacement: 手順 12、 2の画像 1 Nabi Big Tab HD24 Power Button Replacement: 手順 12、 2の画像 2
    • Carefully grab both sides of the white plastic piece with your fingers and gently pull directly upward.
    • Do not pull from the red and black cable as it is not very sturdy and may come undone from the connector.
    FixBotに聞いてみる
    コメントを追加
  13. Nabi Big Tab HD24 Power Button Replacement, Power Button: 手順 13、 2の画像 1 Nabi Big Tab HD24 Power Button Replacement, Power Button: 手順 13、 2の画像 2
    • Locate the power button assembly on the side with all the circuit boards.
    • The power button will be on the side closest to the screen when the device is opened up.
    FixBotに聞いてみる
    コメントを追加
  14. Nabi Big Tab HD24 Power Button Replacement: 手順 14、 1の画像 1
    • Lift up the black plastic tab holding the white fiber cable with the blue tip.
    FixBotに聞いてみる
    コメントを追加
  15. Nabi Big Tab HD24 Power Button Replacement: 手順 15、 1の画像 1
    • Remove the fiber cable with a blue tip by gently sliding it out.
    FixBotに聞いてみる
    コメントを追加
  16. Nabi Big Tab HD24 Power Button Replacement: 手順 16、 2の画像 1 Nabi Big Tab HD24 Power Button Replacement: 手順 16、 2の画像 2
    • Remove the 2 silver 4.5 mm screws holding the power button assembly in place using the Phillips #1 screwdriver.
    • Take out the circuit board and replace it with your new one.
    • Be sure not to remove the black padding along the edge of the tablet.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
4人の作成者と共同で作成されました。
Nathan Lubega
メンバー登録日: 10/05/16
107 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 4-1, Livingston Fall 2016 Cal Poly, Team 4-1, Livingston Fall 2016人のメンバー
CPSU-LIVINGSTON-F16S4G1
4 メンバー
14のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 38
今までの合計 860
