必要な工具と部品
Slide the wide plastic opening tool across the seem, separating it if you can't pry the device open using just the spudger.
この手順で使用する道具:Tweezers$4.99
Use the precision tweezers to gently disconnect the camera ribbon that is connected to the motherboard.
Use the slim plastic opening tool to remove the speaker from its position on the case.
Un-solder the yellow, red, and black wires that connect the volume module to the motherboard.
Use the wide plastic opening tool to slowly pry each side of the battery up.
