はじめに
If the camera is not working correctly follow this guide to replace it.
必要な工具と部品
Slide the wide plastic opening tool across the seem, separating it if you can't pry the device open using just the spudger.
この手順で使用する道具:Tweezers$4.99
Use the precision tweezers to gently disconnect the camera ribbon that is connected to the motherboard.
